Hope Trials Hub
dave33
Do you run the lockring you get with the shimano cassettes? I'm using a tiagra 8spd (6 gears)cassette and because the lock ring thread only just reaches the freehub i think i have done the thread in.
With a questionably accurate tape measure the freehub space for the cassette to fit on is about 28mm. If thats any help.
No it should be fine i say 28mm.
Edited by trialsy
24 mm i know this for a fact
trust me
ash
cant be :- 6 cogs which are 1.8mm thick (8speed) =10.8mm and the spacers which are 3mmx5=15mm if using 8 and 9 spacing
so thats 25.8mm?
thats with 8 speed spacing so the gears wont all work with the 8speed shifter
so you would need a 6 speed shifter, and lets say you use normal cog from an 8speed cassette which are 1.8mm thick so you need 6 of them thats 10.8mm
and the spacers would be 3.5mm thick so thats 17.5mm
add that and you get 28.3mm
so what spacing do hope say to use?
so thats 25.8mm?
no trust me ive got a barrel here in my hand, the length of the body onto which the cogs sit is 24 mm long for the 6 speed version, the barrel on the 8/9 speed version is 35mm long which is the current iso , trust me i helped to develop this hub, there is ample enough room to get on 6 8 speed sprockets and spacers, if the lockring isnt reaching then use one with a longer thread, all mine have always fit
ash
Edited by trialnoir
ok well the only way you will get 6 cogs from an 8 speed cassette would be to use spacers from a 9 speed cassette which are 2.56mm wide
so that a total of 23.6mm (Y)
so if you helped develop the hub, how was it designed?
for 8 speed spacing or 9 speed spacing and what shifter where you thinking in using ? :S
yer i find i have troubles getting the lock ring to reach as well :(
try using spacers from a 9 speed cassette should fit on better pat (Y)
