krissis Posted April 11, 2006 Report Share Posted April 11, 2006 wheel building is an art in its self an should not be attempted by unconfident people, i am not going to tell you a method of building just that you should find your own and practice, trial and error seems to be the best way as the tips and manuals can be very hard to understand and the person who wrote it has probably has been building for years and has found this way suits them. i have tried to take tips off of people but have had no luck.i got a wheel and copied what i saw, bearing in mind if your building a disc wheel have a disc wheel to copy from as they have different lacing patters. finding your own technic may take several hours of wheel building but just go with what feels comftable once you have mastered lacing the wheel perfect dishing and truing, i spent over a couple of weeks perfecting my technics and now build every wheel i use and do builds for friends. Quote Link to comment Share on other sites More sharing options...
Deonn h Posted April 11, 2006 Report Share Posted April 11, 2006 And the point of the topic is? Quote Link to comment Share on other sites More sharing options...
krissis Posted April 11, 2006 Author Report Share Posted April 11, 2006 And the point of the topic is?[/quoteto help others, i hope, i found it very hard to get advise on wheel builds and if someone gave me the advise i have just given then i think i would of found it easier as i tried many ways and still had to resort in trail and error as i could not get my head around what they were trying to put across. Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted April 11, 2006 Report Share Posted April 11, 2006 The one and only link you need to wheel buildingSheldon BrownWhere i learn't many many yeares ago Quote Link to comment Share on other sites More sharing options...
krissis Posted April 11, 2006 Author Report Share Posted April 11, 2006 The one and only link you need to wheel buildingSheldon BrownWhere i learn't many many yeares agowow, very usefull, very similor to my ways of building, verywell explained im sure to pass this sit on to friends, cheers Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted April 11, 2006 Report Share Posted April 11, 2006 Mate non of your posts have been helpfull so far!!!If your gonan do it then do it helpfully in detailWheels building should only be done if you can od everything eles on a bike, that way you know your good at mechaincs Quote Link to comment Share on other sites More sharing options...
Lee Cable Posted April 11, 2006 Report Share Posted April 11, 2006 Mate non of your posts have been helpfull so far!!!If your gonan do it then do it helpfully in detailWheels building should only be done if you can od everything eles on a bike, that way you know your good at mechaincsThat has got to be the biggest load of sh*t I have ever heard. His post isnt that bad, and what are you talking about...\/Wheels building should only be done if you can od everything eles on a bike, that way you know your good at mechaincs I could build a wheel for ages before i could set a derailer up. Dont listen to this guy, he talks out of his arse. From Lee Quote Link to comment Share on other sites More sharing options...
krissis Posted April 11, 2006 Author Report Share Posted April 11, 2006 That has got to be the biggest load of sh*t I have ever heard. His post isnt that bad, and what are you talking about...\/ I could build a wheel for ages before i could set a derailer up. Dont listen to this guy, he talks out of his arse. From Leei wont, i can fix anything on a bike from truing wheels, replacing pistons in hydraulic brake systems to stripping down forks and degreasing, replacing bushes seal or simply changing the oil or setting the rebond (internally, anyone can simply change it if its external ), i built my bike up and service it my self plus im tryin to open my own bike shop but am struggling to get funding, anyone want any tips just ask Quote Link to comment Share on other sites More sharing options...
Simpson Posted April 11, 2006 Report Share Posted April 11, 2006 Wheels building should only be done if you can od everything eles on a bike, that way you know your good at mechaincsBullshit - building a wheel is a closed skill you could teach a 6 year old who knows nothing about bikes how to build a wheel if you spent time with them Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted April 11, 2006 Report Share Posted April 11, 2006 Lacing up is fairly easy pending what you doingTruning is not Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted April 11, 2006 Report Share Posted April 11, 2006 You shouldnt need to true a wheel if its built properly. Simply get even spoke tension and itll build straight Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted April 11, 2006 Report Share Posted April 11, 2006 LaceWind upTighten upTrune upDishJob donePark teach that order Quote Link to comment Share on other sites More sharing options...
N.Wood Posted April 11, 2006 Report Share Posted April 11, 2006 What about pre-stressing? That'll just stress then need re-truing again after the first ride as the spokes settle in. Quote Link to comment Share on other sites More sharing options...
krissis Posted April 11, 2006 Author Report Share Posted April 11, 2006 he's right its best to destress the spokes first by bending um side to side (around each other), then true it again and repeat that until all the creeks and twangs have gone and your wheel is nice and straight. its not that easy as tightening up all the spokes to the same torque and its done because trailing and leading spokes are under diffirent tension. Quote Link to comment Share on other sites More sharing options...
Mr_Pitbull Posted April 11, 2006 Report Share Posted April 11, 2006 You know your the wheel truing master, once you've successfully built a 36H profile (larger flange on each side) onto a 32H Echo Rim, without any signs of a buckle or egg.Piece,James Quote Link to comment Share on other sites More sharing options...
krissis Posted April 12, 2006 Author Report Share Posted April 12, 2006 You know your the wheel truing master, once you've successfully built a 36H profile (larger flange on each side) onto a 32H Echo Rim, without any signs of a buckle or egg.Piece,Jamesyeah if you say so, must look right good with 2 spokes missing if you ask me thats funny, dent you make note of how many spoke holes you needed, Quote Link to comment Share on other sites More sharing options...
dave85 Posted April 12, 2006 Report Share Posted April 12, 2006 Echo rims only come in 32 hole. Profiles (at the time at least) commonly came in 36. And ignoring anything else, Craig made it work therefore it was brilliant Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted April 12, 2006 Report Share Posted April 12, 2006 Ah you mean off-LACING, it's not easy to do at all and most place wil lsay no to doing it Quote Link to comment Share on other sites More sharing options...
Josh!! Posted April 12, 2006 Report Share Posted April 12, 2006 somebody pleaseeeeee tell me what dishing means. i am building a wheel right now and its my first time i have laced everything up corectly i just don't no what dishing is please help. josh...... Quote Link to comment Share on other sites More sharing options...
nova666 Posted April 12, 2006 Report Share Posted April 12, 2006 Kriss taught me how to true wheels and now im doing it everyday N1I use to make my wheels 10 times worse lol. Quote Link to comment Share on other sites More sharing options...
Davetrials Posted April 12, 2006 Report Share Posted April 12, 2006 And the point of the topic is?shut up u idiot Quote Link to comment Share on other sites More sharing options...
cvtrial Posted April 12, 2006 Report Share Posted April 12, 2006 shut up u idiotAnd what was the point in posting that? Getting more posts? But, anyways... I think this topic helps many newbies haha Quote Link to comment Share on other sites More sharing options...
