Front Brakes
joe parker
If you dont have a lot of money, go for an Avid V-brake, i have had one for nearly 2 years and its never let me down, although the power has gone down, another plus about V-Brakes are that they are cheap to run, becuase its a cable brake, you need a lever, cable, hosing and the brake itself, and there is no future phaffing around with bleeding, all you do is change the pad.
If you have a little bit more money go for an avid Mechanical Disc, they are cable aswell so no need to worry about bleeding them, they are easy to set up and offer great power and modulation, aslo the rotor that comes with it looks ace.
Al
