Chains
i currently run the Kool chain on my bike but want something better because my kool has got 8 stiff links after only 4 months of being used so really the question is what other chains are out there worth using
i'm thinking
shadow conspiracy chain http://www.customriders.com/prodshow.asp?id=6524&pg=1&site=3
but don't know how it would run any replies will be appreciated
If you've got stiff links try loosening them a little... stick 2 allen keys in the slots of your chain intended for chainring/sprocket teeth to go into and give it a little twist. This will widen the area that was compressed when the chain was re-attached using a tool.
If not the shadow chains are hefty things and should be fine for you though many people whinge about them stretching but i wouldn't be bothered if i was you. You might want to consider something a little cheaper though like the KHE recommended above.
The shadow chain should be great for trials on the paper side of things as its made entirely of whats called 'half links' this increases the chains breaking amount which is measures in nuetons (sp..)Also it would be more suited to the gear ratios we run in ,these in bmx called 'micro gearing' .
Edited by watto
