Loose Head Set 1 1/8
wayneone
My head set on my planet x zebdi has come loose and i have no idea how to fix it.
THe head set its self is just a black one with no brand, It feels like its loose at the bottom as the forks wobble if you shake the bike. No i have no reason to belive the head set is flared at all becuase ive only ridden the bike 2 times and i noticed it straight away(after my mate built it)
So how do i tighten it back up? keep in mind i dont hjave a headset press.
loosen the stem bolts, tighten the top cap bolt, re-tighten the stem bolts, should be ok. (Y)
Otherwise it's not loose, maybe the bearings have been put in wrong or something, but try that ^^^ first of all..
