TheFabricator Posted April 7, 2006 Report Share Posted April 7, 2006 cheap disc brake set ups can be had off ebay for a fiver. they are ex mini moto and brand new. they are cable, but they do come with disc, caliper and pads, adaptor for 10mm axle and lever. The disc is only 120mm diameter so you have good ground clearance but the calipers have really big pads and are way more powerful than ordinary bike cable disc setups. OK you need a disc front hub but what do you want for a fiver. your thoughts? Quote Link to comment Share on other sites More sharing options...
JT! Posted April 7, 2006 Report Share Posted April 7, 2006 (edited) The sise of the pad does not have any effect of the power of the brake.It's a very very small rotor, it'll use really really cheap parts, so i doubt your going to get any braking power out of it what so ever.But, seing as the price is so low, why not buy it and tell us? Edited April 7, 2006 by JT! Quote Link to comment Share on other sites More sharing options...
Camster911 Posted April 8, 2006 Report Share Posted April 8, 2006 "They are way more powerful than normal bike brakes" - If you belive that , buy them fool , and tell us what there like. Quote Link to comment Share on other sites More sharing options...
watto Posted April 8, 2006 Report Share Posted April 8, 2006 In theory they should be at the same level of performance or better than mtb disc brakes as they have to slow down from higher speeds, but what is wrong with just getting a brake that you know will work. Yeah as said before get one and try it, if its good you could be on to something(by saving a lot of people money), but if it ain't just stick it back on ebay. Quote Link to comment Share on other sites More sharing options...
