My Bike Is Finally Finished! What Do You Think
Nice but been built wrong!
Rear magura you've the evo moutns wrong way thus stressing and damiging your slave.
Swap the mount left for right right for left, they are ment to be parrale/vertical not at a V
Grind them rims
with them the other way round you wont be able to get the rim in......... pads will touch the rim! its not gonna dammage the cylinders that much anyway... i ran mine evo mounts the wrong way round to fit the rim in and im still using the same maggy 2 years on.
joshywa
joshywa
Thanks mate! yes! that is true! i have to have them at that angle otherwise my wheel wouldnt move.
plus i dont need to frind my rims my bakes are perfect and if they lose power u just spray hairspray on the rims or monty spray and there perfect again! or i will get plasmatic pads (in green :D )
Grind them rims
They're evo II mounts, they're f**king symetrical it won't matter which way round they are!!!
Whack some old style evo mounts on the back and you should be able to set the rear brake up fine.
Edited by Krisboats
