Davetrials Posted April 7, 2006 Report Share Posted April 7, 2006 3 of my mates have 06 echo rims and all there brakes are elwanko, does anybodys work? Quote Link to comment Share on other sites More sharing options...
Punkrider Posted April 7, 2006 Report Share Posted April 7, 2006 Yes, it's called a grind Quote Link to comment Share on other sites More sharing options...
Greetings Posted April 7, 2006 Report Share Posted April 7, 2006 I run disc but my mate has a magura oil bleed with custom pads (made by another friend), ground rim and it works perfect! Give the rims a grind! Quote Link to comment Share on other sites More sharing options...
Davetrials Posted April 7, 2006 Author Report Share Posted April 7, 2006 they are ground u tits, beefy grinds as well. Quote Link to comment Share on other sites More sharing options...
tipsy Jock Posted April 7, 2006 Report Share Posted April 7, 2006 they are ground u tits, beefy grinds as well.Mine worked ace before the grind wore out, koxx bloxx or coust pads + echo rim makes for a great brake Quote Link to comment Share on other sites More sharing options...
Davetrials Posted April 7, 2006 Author Report Share Posted April 7, 2006 how long did ur grind last? Quote Link to comment Share on other sites More sharing options...
Ali Courtney Posted April 7, 2006 Report Share Posted April 7, 2006 My brake wasn't to bad on my Echo 26", not the best but now the rim is trully dead, uberly flat spotted to the point where the tyres wont stay on Cheers Ali Quote Link to comment Share on other sites More sharing options...
Pauly Posted April 7, 2006 Report Share Posted April 7, 2006 they are ground u tits, beefy grinds as well.yeh mine is a beast im running koxx blues atm i did notice a little bit of a decrease when i changed rims in the sound of my brake but it works awsome for me, but personaly i wouldnt get this rim the amount of times ive had to bash mine out from putting flat spots in it is shocking so....Pauly Quote Link to comment Share on other sites More sharing options...
downhill_rob2@hotmail.com Posted April 7, 2006 Report Share Posted April 7, 2006 My brake is awesome. bloxx browns on a medium grind....ground lasts 2 months (ground just before the newcastle ride, then had to regrind the other day...) Quote Link to comment Share on other sites More sharing options...
sexymike Posted April 7, 2006 Report Share Posted April 7, 2006 interesting, all of you! loli simply cant get it to work, 3 grinds, no luck Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted April 7, 2006 Report Share Posted April 7, 2006 interesting, all of you! loli simply cant get it to work, 3 grinds, no luckmine came with what looked like light oil coating....sooooootry this sexy boi......degrease the rim, wash it off with water, let it dry, re-grind it with a new disc(because the old one will have oil on it if this is the problem) either use new pads or file a load off the surface hope this helps Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted April 7, 2006 Report Share Posted April 7, 2006 i simply cant get it to work, 3 grinds, no luckWhat pads are you using Mike? Quote Link to comment Share on other sites More sharing options...
Bigman Posted April 7, 2006 Report Share Posted April 7, 2006 What pads are you using Mike?At a guess Adam i would say Majic pads..........I may as well add that my brake was AWSOME on my echo rim, i was running CNC backings and red pads and it was silly Adam Quote Link to comment Share on other sites More sharing options...
the judge Posted April 7, 2006 Report Share Posted April 7, 2006 At a guess Adam i would say Majic pads..........AdamCorrectamundo Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted April 7, 2006 Report Share Posted April 7, 2006 Haha, just kidding.I've found that you need to use less 'sticky' material on rims like Echo and Onza Hogs, or they just get loads of aluminium stuck to them and don't work. As far as I remember, the Majics are a bit like that yellow stuff Stan used - which was awful for getting glazed. Plaz are a good bet since theyre not 'sticky' at all, much more waxy. Quote Link to comment Share on other sites More sharing options...
Gaz M Posted April 7, 2006 Report Share Posted April 7, 2006 when he says does anyones brake work he doesnt mean grind it and it makes a shite swooshing noise, a proper beasty squeak and good hold, waddys sounded alright dave he was using majics cut down to 30mm, try that ? Quote Link to comment Share on other sites More sharing options...
tipsy Jock Posted April 7, 2006 Report Share Posted April 7, 2006 how long did ur grind last?Erm from that funtrial in Keighley, when was that febuary? until last week when i rode in the rain and it wore smooth. So wahts that about a month and half i think Quote Link to comment Share on other sites More sharing options...
NeillyB Posted April 7, 2006 Report Share Posted April 7, 2006 Plazmatic CRM's + my Echo 2006 rim, no grind = amazing. Don't know where everyone else has gone wrong... Quote Link to comment Share on other sites More sharing options...
manuel Posted April 7, 2006 Report Share Posted April 7, 2006 3 of my mates have 06 echo rims and all there brakes are elwanko, does anybodys work?You know mine is amazing.... Quote Link to comment Share on other sites More sharing options...
MaXsteri Posted April 7, 2006 Report Share Posted April 7, 2006 Plaz on a dead grind works awesomely on the back for me.And heatsink blues on a unground front gives nice (some) modulation which feels good Quote Link to comment Share on other sites More sharing options...
