Mod 1010 - 1020 Wb
<<(Tom_182)>>
The chances are that the echo will be longer than 1000.My zoo short is ment to be 1005 and it is 1030.So why not try a gu short
it will probs be around 1015 as you have to tension your chain.(Y)
Edited by Deonn h
yeh. It must be those far easton tape mesures lol.
Actually, if you think about it, they are those lenghts because they are the 'fixed' wheelbases, there was a little diagram of a Monty frame drawing with geometry measurements, the chainstay/wheelbase measurement was taken from the deepest length the axle sits into the dropout. It's more accurate this way to display a product, but less accurate if you want a realistic exact measurement.
Mod frames are gonna be longer wheelbase wise in real life compared to the factory measured lengths as seen on websites. Up to around 20-30mm longer perhaps sometimes.
Making a CLS Python... have like 385 or even more chainstay length if you measure it realistically :o
