thesoupdragon182 Posted April 3, 2006 Report Share Posted April 3, 2006 I have a 26" farme with no disk mounts and only magura mounts is it possible to run 24" wheels on this Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted April 3, 2006 Report Share Posted April 3, 2006 yeah, but you will need an adaptor platei shall soon post up my 24inch justice when its built Quote Link to comment Share on other sites More sharing options...
thesoupdragon182 Posted April 3, 2006 Author Report Share Posted April 3, 2006 Thats what am doing it to my justice but would the adaptor be for a disc or is it possible to use to plates on the magura mounts to muve the magurs down Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted April 3, 2006 Report Share Posted April 3, 2006 ive made a plate that bolts onto the 4 bolts, and runs a lower mount for a v brake cos maguras suckive done it before to convert a tee vee to a 19inch wheel, works fine Quote Link to comment Share on other sites More sharing options...
montyrider Posted April 3, 2006 Report Share Posted April 3, 2006 (edited) Thats what am doing it to my justice but would the adaptor be for a disc or is it possible to use to plates on the magura mounts to muve the magurs downHey thier, i have a monty and the 4 bolt mounts are made for 25" wheels so a made some adapters that are tidy as, which means i can run 4 bolts on a 26" wheel in my frame if i had a camera i would show you what i did, i dont know if you can buy these sort of things but just make some brackets if you can to move your 4 bolts down a couple of inches Edited April 3, 2006 by montyrider Quote Link to comment Share on other sites More sharing options...
thesoupdragon182 Posted April 3, 2006 Author Report Share Posted April 3, 2006 Thats what a think am going to do make an adaptor and run 24s Quote Link to comment Share on other sites More sharing options...
montyrider Posted April 3, 2006 Report Share Posted April 3, 2006 Thats what a think am going to do make an adaptor and run 24sGo for it mate make the mounts so they can be adjusted a little bit (up and down) so you can move them to exactly where you want them, thiswill save you having to make another set you dont measure the exactly how you need them.I did that quite annoying really! Quote Link to comment Share on other sites More sharing options...
