MikeCottTrials Posted April 1, 2006 Report Share Posted April 1, 2006 ok so i've just got my new 20mm axle hub and fork but when i try to push the actual axle through the hub it gets stuck on the left(i think) side. this is my first 20mm setup so bear with me but has anyone got any ideas, is this common with 20mm setups Quote Link to comment Share on other sites More sharing options...
ogre Posted April 1, 2006 Report Share Posted April 1, 2006 For a trial bike isn't a 20mm axle a bit HUGE? (especially on the front) Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted April 1, 2006 Report Share Posted April 1, 2006 I think someone did make emAnywas What hub and fork and what is the axle off? Did it come with the forks?Usally they can be a bit of a tight fit, the hub is ment to roll on them kinda but also using the hubs bearing too. Have you made sure it's evenly in the 20mm cones?Have you tried it with just the wheel only no forks near it at all to se eif it's the hub or axle? Quote Link to comment Share on other sites More sharing options...
MikeCottTrials Posted April 1, 2006 Author Report Share Posted April 1, 2006 ive sorted it now, it was just a matter of using some serious strength Quote Link to comment Share on other sites More sharing options...
joe_eyre Posted April 1, 2006 Report Share Posted April 1, 2006 :-Hi thereHow come your running a 20mm axel on the front lol, Im sure you dont need anything more that a 10mm axel but meh if thats what you want Cheers Joe Quote Link to comment Share on other sites More sharing options...
TheFabricator Posted April 2, 2006 Report Share Posted April 2, 2006 its for when your droping off 37 pallets and your fw skips. Quote Link to comment Share on other sites More sharing options...
MikeCottTrials Posted April 2, 2006 Author Report Share Posted April 2, 2006 nah its not for a trials bike its for my DMR sidekick, its going to be a street beast plus ive just started to get my spins going on so hopefully it should all be coming together Quote Link to comment Share on other sites More sharing options...
