Koxx Tyre Pressure
daniel 34
However much you want really mate...people usualyy run lower pressures for natural riding than street, i'd go say 5-10 psi lower than you've got in the back tyre if thats any help.
go for around 15-20??? lesser the pressure=more grip
Edited by montyrider
Hi there
I think most people decide for thereself. All you need to do i pump your tyre up until you feel happy with the pressure. Everyone ride different pressures. So just experiment. Like i ride mine mega flat :P thats how i like it but meh..
Cheers joe :sleeping:
I use mine rely rely low but it more grip and bounce but more punchers,but it depends on how big you are and how much you way also how hard you ride but you are just staring so you are no going to be doing 10 foot drop's so i think about 20 psi but it is up to you.
I run my tire pressure on the front at around 5psi. Although i have had koxx tires in the past and with so much tread on the front tire id recomend running it at a farely high pressure in contrast to the pressure you would run in the rear.
So: 8psi Front
10psi Rear
8psi Front
10psi Rear
This kids got monty recomended tire pressures :Plol
on my stock 25 rear and then depends what im doing depending in the ride usually pump up to 35psi then when i get there let a majority of that out
