Random Stupid Faq's
mr kenny
:- well lets tell each other random stupid faq's that'll make folk smile or think what the fukk?
it's got to have some kind of truth to it you know not just a load of stupid shit
i'll go first
sharks only attack you when your wet!
how do you make explosive material with just a cat and a teaspoon?
Is the moon really made of cheese?
How long is a jiffy?
What happens if a dog has unprotected sex with a fish? what abortion methods are there?
that would make a mobile explosive charge. the cat would be a carrier - when you hold the cat by his head and pull the tail hard, the spinal cord snaps and apparently causes the cat to run in a straight line and then die. therefore if the cat is the carrier, the spoon must be the explosive. have him eat the spoon first and place a remote detonator on his nose. that should cause the spoon to explode when the cat runs into something.
hope that helps (Y)
Ok, hovver your hand above a shark tank, see what happens.
spider silk is stronger than steel.
.....per unit of mass. :rolleyes:
Edited by JT!
