Ben Geary Posted March 31, 2006 Report Share Posted March 31, 2006 Well the other day i thought i would take my headset of and grease it all up, so i took it all of cleaned it all and then put fresh grease on.Then i put it all back on etc and it just wouldnt stop clunking in the bottom cup and working loose causing play .... so i took it all apart just to check every thing was alright witch it looked fine to me, but it still carried on making clunking noises, i'm sure it's the bottom cup becuase i can see the movement comign from the bottom cup.The top one seems fine just something with the gay bottom one.Anyone had this problam ?This is my headset ...[attachmentid=3350] Quote Link to comment Share on other sites More sharing options...
Hobnobs Posted March 31, 2006 Report Share Posted March 31, 2006 You sure you put it all in the right way up? Maybe got some of the bearings or washer in upside down, or just stuff from the top cup in the bottom one? Quote Link to comment Share on other sites More sharing options...
NeillyB Posted March 31, 2006 Report Share Posted March 31, 2006 Do you use a headlock or a starnut? Did you tighten the headlock / starnut up before the stem? Quote Link to comment Share on other sites More sharing options...
Guest Posted March 31, 2006 Report Share Posted March 31, 2006 You sure you put it all in the right way up? Maybe got some of the bearings or washer in upside down, or just stuff from the top cup in the bottom one?Thats what I would have thought too, I know I did it with my pig and was like 'wtf is going on this is brand new' and then realising I had been a tit.Also the thing about thightening the star nut/headlock before the stem is very important too and is often over looked.How were the bearings themselves and the surfaces upon which they sit? all nice chamfers still? no signs of wear? Quote Link to comment Share on other sites More sharing options...
Jez Posted March 31, 2006 Report Share Posted March 31, 2006 Good points all - check the bearing surfaces for pitting while you're there, that's always a bad sign. If it's brand new there really shouldn't be owt like that though. Quote Link to comment Share on other sites More sharing options...
Ben Geary Posted March 31, 2006 Author Report Share Posted March 31, 2006 Right i've tried everything possible and it's still making a clunky noise here and there when i'm doing something to front wheel.Guess i'll just have to get a new Headset now,Cheers for the help people,Ben . Quote Link to comment Share on other sites More sharing options...
Onza Kieron Posted March 31, 2006 Report Share Posted March 31, 2006 Is the headset fully in the frame? is the headtube flared? is the cup of the headset snapped off the part that goes into the frame? I don't really know what's wrong, try these, if it shows none of these, find a friend, buy him a mars bar and once he has eaten it, ask if you can borrow his headset to try in your frame, if he says no, throw it all in his face about the mars bara nd so... Hope this helped as I'm tired and it's getting late. Night all... Quote Link to comment Share on other sites More sharing options...
Krisboats Posted March 31, 2006 Report Share Posted March 31, 2006 Or i could fix it for you tomorro. I mean nobody else noticed that boumsong had left out the lower bearing race on his headset till i looked at it and said it wasn't there. Quote Link to comment Share on other sites More sharing options...
Clarky Posted April 1, 2006 Report Share Posted April 1, 2006 Gears if you have checked out the fsa website you get a insrtuction manual wich shows u how to put it together, u may of put the bottom cup wich goes on the bottom of the fork steerer upsideown.Clarky Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted April 1, 2006 Report Share Posted April 1, 2006 got the right race on the fork steerer?i got mine confused with an old headset before..adam Quote Link to comment Share on other sites More sharing options...
Gavyn. Posted April 1, 2006 Report Share Posted April 1, 2006 got the right race on the fork steerer?i got mine confused with an old headset before..adamdid he put it on at all thats what my bro did sounds like whats happened to you Quote Link to comment Share on other sites More sharing options...
DAB Posted April 3, 2006 Report Share Posted April 3, 2006 Those fsa orbits with the needle bearing on the bottom, it's more than likely the bottom cup has cracked where the collar goes in the frame... i've done this before to many of them head sets as i used to have them under a sponsorship... if it is! at least get a pig, they take the stick.. Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted April 3, 2006 Report Share Posted April 3, 2006 yeah ive cracked one before, they arent all that strong probably just better to upgrade to a pig now ben, feckin ace headsets and last ages Quote Link to comment Share on other sites More sharing options...
