Bluegrass Posted March 30, 2006 Report Share Posted March 30, 2006 It seems both my brake lights arn't working, Ive had problems with them for a while. Bulbs seem to go within a matter of weeks. Ive had new foot brake switch (dont know what its called, switch under the foot brake that turns rear brake lights on...) not so long ago, so surely this couldn't have gone again?! Could it be re-wiring needed etc? Getting desperate as i NEED the car over the weekend urgently. Pug 106 if it helps. Thanks for any advice Quote Link to comment Share on other sites More sharing options...
Jonny Jones Posted March 30, 2006 Report Share Posted March 30, 2006 Check the fuse box. Usually somewhere under the steering wheel J. Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted March 30, 2006 Report Share Posted March 30, 2006 You've probably got a short somewhere. Take the lights out and check that the wires arent worn or been rubbed through on the body Quote Link to comment Share on other sites More sharing options...
Caleb Posted March 30, 2006 Report Share Posted March 30, 2006 Could also check the tail light wiring loom and the live connectiopn at the back to make sure it has good connection, that was the problem with mine anyway Quote Link to comment Share on other sites More sharing options...
wayneone Posted March 30, 2006 Report Share Posted March 30, 2006 Are you changing the bulbs yourself? make sure you dont touch the bulb directly with your hands wrap it in a tissue. Quote Link to comment Share on other sites More sharing options...
Bluegrass Posted March 30, 2006 Author Report Share Posted March 30, 2006 How come? Quote Link to comment Share on other sites More sharing options...
Simpson Posted March 31, 2006 Report Share Posted March 31, 2006 i think thats only true with halogen bulbs (16 and know little just thought may help dont know technically why something to do with chemicals???) Quote Link to comment Share on other sites More sharing options...
the_soon_to_be Posted March 31, 2006 Report Share Posted March 31, 2006 with halogen bulbs, the salts in you sink react with the glass and weaken it, so not only do they not last as long but when they blow, they don't just burn out, the glass itself can explode Quote Link to comment Share on other sites More sharing options...
spencer@hulltrials Posted March 31, 2006 Report Share Posted March 31, 2006 i think you'll find that touching a halogen bulb with your fingers makes no difference to the life of the bulb, it merely creates a oilly patch on the bulb which lasts for a few minutes at the most when the bulb is in use. Quote Link to comment Share on other sites More sharing options...
wayneone Posted March 31, 2006 Report Share Posted March 31, 2006 i think you'll find that touching a halogen bulb with your fingers makes no difference to the life of the bulb, it merely creates a oilly patch on the bulb which lasts for a few minutes at the most when the bulb is in use.Not what ive been told by several mechanics.A bit of topic but if you decide you want metal blingy dust caps but dont want little f**kers stealing them and decide to spanner them up tight just remember to grease the thereds as they can corrode onto them! Quote Link to comment Share on other sites More sharing options...
