Heatsink Reds Or Coust On Light/dead Grind.
Deonn h
I REALY like my read compund in my CNC pads, i am currently running it on a PROPERLY dead grind on a DX32 in my ashton, they hold sooooooo well........
On the bike at the moment the power is a little different than when i had them on the control, on the control they were BITEY BITEY uber loud pads, on the ashton they are not so bitey, they have a little modulation (which on the ashton is nice :P) but when the brake is needed they hold SOOOO well, they are also currently perfectly silent, which i am loving..........
So yeh, in my oppinion go for the reds, they are also cheaper (Y)
Adam
i know you said those two but plazmatic crms ar emeant to be ace on a light grind, i aint sure on others.
I run plaz now.They are good but what i`ve found is that they slip abit , they make an awsem noise though.Might be cause of my flexy frame and bolts but that will be sorted with cnced mounts backings and a fresh bleed. :)
I forgot to mention one VERY important thing about the reds.....
Where plaz pads are SHOCKING in the wet, the heatsink red pads are PHENOMINAL they are realy realy good in the wet!!!!!
Adam
Mint , thats the main problem with plaz.
In my CNC'ed backings at the moment i am running 1 plaz and 1 coust pad, my brake squeeks realllllllly loud and holds really well and it worked good in the wet too. if you are things of putting plaz material in it's simple all you do it get the out of the backings and cut the down slightly and then they fit in with abit of super glue. I would also think that 1 Koxx bloxx green and 1 coust work work maybe even better, experiment :P Sorry if i have woffeled on :-)
Tom.
The only time my reds work is in the wet (N) go for coust unless you plan on a fresh grind.
I've actual started putting light grinds on my koxx rim just to get them to work with out tar but that only lasts an hour or two the its back to tar :( cousts on the other hand seem to be amazing on a smooth rim so they'd probably get my vote.
The only positives i've found with the reds are they feel so solid and (when not using tar) are silent as a baby, if you want to use tar go for it but i won't be getting red re-fills.
joshywa
No really. Really, it's shit. Properly, turd. I put my other Koxx green on and my brake became uber, and has remained uber. Seriously, Koxx greens don't f**k around :P
I heard that!
I'm on my 3'rd pair of koxx greens now, and i love them, such good hold and amazing performance in both the wet and the dry.
Get them!
Ian
I heard that!
Get them!
Ian
:o:O:O:O:O:O:O:O
That's person #3 who's actually realised how cunting awesome Koxx greens are... I'm still on my first pair, bought at the bike show last year ;) (Used some 'sink blues, Konigs, something else and something else since then, but they've been on for at least 6 months in total, and are half-way worn)
I've got heatsink reds in CNC Vee backings (yeah, I know but it's the same pad material, right?). They seem awesome on a smooth rim, but I've only ridden 'em in the rain once, and the rim was well clean then. They seemed fine at the time, but yet to see what they're like on a well-ridden rim in the wet.
I've just whacked some on my stock which has a very light dead grind on the front, will advise after a few days. They seem good new, but as well all know that don't mean shit.
I haven't got on to well with my heatsink reds/cnc backings, I'm running a ronnie and the pads wear down the grind in about 3 days and then don't work particularly well after that, I also found that the managed to collect a lot of dirt/dust and then when i ride in the rain in all washes onto the rim making the brake even worse,
Majic pads next (Y)
