21tooth Chainring?
Luzac
i cant find someone who sells 21t chainrings, 5 bolt CD
the reason that i'm lloking for one is that im currently running an eno at the rear. wich we're all aware of they just come in 18t :/
i belive that 21/18 should be the perfect ratio for me,
i've found this site: http://www.boonerings.com/cr/cr.html wich sells custom TI chainrings, but i think that it might would be to weak for a trials sprocket?
or should i get some FFW cranks, a 21t fixed sprocket and a threaded bash?
thanks/Lucas
As far as im aware they dont make 21 tooth the only ones i have seen are 22t (which i run) and 20t sprockets.Race face are very good and hard wearing sprockets ive had mine over a year alot better than the onza ones. Have you looked on the mountainbike sites such as chain reaction and bike dock .
Edited by watto
As far as I'm aware standard inner chainrings only come in even numbers so a custom chainring would be the only option if you were to keep your cranks. If you have the money it would probably be worth upgrading your cranks and just buying a 21 tooth screw on fixed sprocket and a bash.
