Josh!! Posted March 28, 2006 Report Share Posted March 28, 2006 hi im in need of some new pads and i was wondering if the zoo pads were any good on a smooth rim. ive heard that cls dosent use a grind and his brake is immense please help cheers josh Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted March 28, 2006 Report Share Posted March 28, 2006 Yes. Smooth rim Grind Such a soft compound. But yeah, immense I hear Quote Link to comment Share on other sites More sharing options...
Josh!! Posted March 28, 2006 Author Report Share Posted March 28, 2006 what pads would you reccomend as i really dont know ive had heatsink reds koxx yellows both good pads but just want a change Quote Link to comment Share on other sites More sharing options...
TheFabricator Posted March 28, 2006 Report Share Posted March 28, 2006 We use Zoo greens on a std Monty rear rim with no grind, but we do use hair spray on the rim. Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted March 28, 2006 Report Share Posted March 28, 2006 what pads would you reccomend as i really dont know ive had heatsink reds koxx yellows both good pads but just want a change Well, On my bike... Rear - Plaz CRM's on a smooth grind. -Works really well...in the dry. Front - Tensile Bubble gum pads on a smooth grind - Also works really well. Makes a horrid noise But locks well, and still has modulation. Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted March 28, 2006 Report Share Posted March 28, 2006 I dont think majic pads have had one bad review yet, so I sugest them Quote Link to comment Share on other sites More sharing options...
JT! Posted March 28, 2006 Report Share Posted March 28, 2006 We use Zoo greens on a std Monty rear rim with no grind, but we do use hair spray on the rim.Try tar. I use zoo pads ona smooth rim, little tar and it's the best brake i've ever felt. Only problem is though it's a very temperature dependant setup. Goes a bit crap in the cold. Quote Link to comment Share on other sites More sharing options...
GlynnP Posted March 28, 2006 Report Share Posted March 28, 2006 I dont think majic pads have had one bad review yet, so I sugest themi had majic pads they arnt all they r cracked up to be they were ok but not great didnt always grab fantastic or lock sometimes.Try tar. I use zoo pads ona smooth rim, little tar and it's the best brake i've ever felt. Only problem is though it's a very temperature dependant setup. Goes a bit crap in the cold.i use zoo with a smooth rim and they are great. no need for tar any pad will be good with tar Quote Link to comment Share on other sites More sharing options...
JT! Posted March 28, 2006 Report Share Posted March 28, 2006 any pad will be good with tarI really hate it when people say that.I ride with someone who uses kool stops with tar, and i use zoo pad with tar. My brake is good, his is crap. It sticks, and you can sometimes feel the pads roll over the top of the tar.The better the pads are the less tar you have to use, with kool stops, you have to use loads. Sure the hold might be the sameish (well it isn't really, the hold is shite), but the quiality of braking isn't.So no, not every pad is great with tar. Quote Link to comment Share on other sites More sharing options...
aaron-i'anson Posted March 28, 2006 Report Share Posted March 28, 2006 (edited) Yes Zoo pads have an amazing grip on a smooth rim with the outstanding cherp aswell.However i would say that they're not that good in wet weather.Then again its spring and the weather should be mint. So i give you a strong advice to get them.Aaron Edited March 28, 2006 by medway_trials Quote Link to comment Share on other sites More sharing options...
Ewannnn Posted March 29, 2006 Report Share Posted March 29, 2006 majic pads are ok with a grind i suppose, wear down fast though, mine have almostly completely gone after 1 month of using it on a grind thats not quite harsh but not light either Quote Link to comment Share on other sites More sharing options...
munch8987 Posted March 29, 2006 Report Share Posted March 29, 2006 Go for the Zoo! pads matei use them on my stock and they are fantastic on a smooth rim Admitidly they are a soft compound,but have,in the last 3 months had a medium grind on the rear rim....and i've only seen about 1mm of wearHope this helpsBen Quote Link to comment Share on other sites More sharing options...
