Keeps Bending Rear Axles
My lad has a Monty Magura and practises on pallets.If he climbs on and rests on the chain it bends the rear axle every time. Is there a block or something available to fit between the chain and stay. if not im going to weld one on the the back of the bash guard or something to try and stop it. what do you seasond lads do.
Hmmm, not exactly sure what you mean here ... You're actually bending axles regularly ? sounds like the wheel simply isn't tightened enough , allowing it to move when pressured ie by the chain , without causing any damage to the axle itself .
that was fast thanks for your replies.it is the increase in chain tension caused by landing on the chain which pulls hard on the sprocket and bends the axle. the axle cant pull forward as its tight and held by a cam against a stop bolt in the frame.so it bends.its the section of chain between the tyre and the bash plate wich is vunerable.
So.. the wheel's tight, and when he bashes, the wheel slips in the dropouts?
I guess you could try wedging something in the dropouts, weld it in or something, like you said.
You can get washers with a sort of 'grip' on them too, you could perhaps out thopse on the axle, inbetween the wheel nut, and dropout.
Hope I've understood you correctly, and you'll understand me correctly. :turned:
Nylon block is the ticket, its quieter than a chunk of metal. I had one with a few holes drilled through it from side to side and then cable ties holding it to the stay. Not overly secure but it worked well.
