KeNi Posted March 25, 2006 Report Share Posted March 25, 2006 Ok, Ive just bought a brand new headset for my koxx levelboss and i got it home i fitted it, it all looks right and it is loose as f**k! Quote Link to comment Share on other sites More sharing options...
Joe_Kearney Posted March 25, 2006 Report Share Posted March 25, 2006 What headset is it, and in what way is it loose, you need to elaborate more.... Quote Link to comment Share on other sites More sharing options...
KeNi Posted March 25, 2006 Author Report Share Posted March 25, 2006 it is a vp headset it is just wobbling Quote Link to comment Share on other sites More sharing options...
Joe_Kearney Posted March 25, 2006 Report Share Posted March 25, 2006 At a wild guess you could try putting some spacers in? Or try google, search for headset fitting because there may be something you missed out/forgot Quote Link to comment Share on other sites More sharing options...
Mark W Posted March 25, 2006 Report Share Posted March 25, 2006 Is there any gap between the base of the headset cup and the end of the headtube?Have you put the correct bearings in each end?Have you got enough stem stackers (the top-cap SHOULDN'T touch the top of the fork steerer tube, if it does, it won't be tight enough)?You may also need to take the stem off, take off any spacers, take off the top cap, and then make sure that the split washer that goes on-top of the bearings/bearing cap is seated properly. I was fitting a headset up yesterday and it wasn't quite seated properly and it kept moving. Anyway, check that that's all right.Lastly, if it's sealed, it'll take a while for the bearings to bed in anyway Quote Link to comment Share on other sites More sharing options...
