froggy Posted March 24, 2006 Report Share Posted March 24, 2006 I'm planning on getting a new frame, shiney one but I want to respray it. Just wondering how do you spray polished aluminium?For example, the Echo Hi-Fi and Onza T-rex frames. Quote Link to comment Share on other sites More sharing options...
mat hudson Posted March 24, 2006 Report Share Posted March 24, 2006 sand it to give the paint somthing rough to stick to. primer, then colour then laquer. Quote Link to comment Share on other sites More sharing options...
Greetings Posted March 24, 2006 Report Share Posted March 24, 2006 yeah, you need to sand it otherwise the paint will just fall off Quote Link to comment Share on other sites More sharing options...
froggy Posted March 24, 2006 Author Report Share Posted March 24, 2006 hmmm, ok.does anyone know any good places online to order spray from? The only place I know to buy spray paint is halfords and they only have a small range. Quote Link to comment Share on other sites More sharing options...
ARSE! Posted March 25, 2006 Report Share Posted March 25, 2006 hmmm, ok.does anyone know any good places online to order spray from? The only place I know to buy spray paint is halfords and they only have a small range.Halford, B&Q or your local DIY shop is your best bet, or a car garage if you ask them nicely. Quote Link to comment Share on other sites More sharing options...
nmt_oli Posted March 25, 2006 Report Share Posted March 25, 2006 Maybe your halfords is bad- but the one i work at has a whole isle! Most shades your find on road cars are there in rattle cans, along with general purpose paints in a diff section.If you don't like the colours there, and there IS a good selection, they can mix some up if you have a colour code.Definately make sure the surface is roughed up nicely with medium wet and dry, then a couple of coats of primer, then couple of colour, then a few of laquer. leave 10-15 mins inbetween thin coats and at least an hour or so between primer, colour and colour and laquer. Leave the frame somewhere warm for 24 hours before building it up.If you want a really smooth finish, use more coats of paint, thinner coats, and in between each stage sand down with wet very fine wet and dry paper, before cleaning drying and continuing. Quote Link to comment Share on other sites More sharing options...
Prawny Baby Posted March 25, 2006 Report Share Posted March 25, 2006 Maybe your halfords is bad- but the one i work at has a whole isle! Most shades your find on road cars are there in rattle cans, along with general purpose paints in a diff section.If you don't like the colours there, and there IS a good selection, they can mix some up if you have a colour code.Definately make sure the surface is roughed up nicely with medium wet and dry, then a couple of coats of primer, then couple of colour, then a few of laquer. leave 10-15 mins inbetween thin coats and at least an hour or so between primer, colour and colour and laquer. Leave the frame somewhere warm for 24 hours before building it up.If you want a really smooth finish, use more coats of paint, thinner coats, and in between each stage sand down with wet very fine wet and dry paper, before cleaning drying and continuing.if you REALLY want a smooth finish, dont bother with the laquer......laquar is for gays im afraid, theres no real need for it!if you can, try baking it, when i sprayed my bt, i suspended it in an upturned bike box over an oil radiator overnight, the temp in the morning was 48 degrees inside the box!!!!once its baked on hard, flat it all down again with 1200 or 1500 wet n dry, used very wet with a touch of fairy liquid in the warm water.then itll look dull as fook, and you need to spend hours with a finishing compound to bring it back to a perfect mirror shine......takes ages, but its well worth it Quote Link to comment Share on other sites More sharing options...
DAB Posted March 25, 2006 Report Share Posted March 25, 2006 (edited) Don't f#ck about trying to spray it your self get it powder coated look in the yellow pages or go on line theres loads of people that do it, i used a company they powder coat washing machines, they they did a great job, left it with them for 1 day and cost £25 Edited March 25, 2006 by DAB Quote Link to comment Share on other sites More sharing options...
froggy Posted March 25, 2006 Author Report Share Posted March 25, 2006 Don't f#ck about trying to spray it your self get it powder coated look in the yellow pages or go on line theres loads of people that do it, i used a company they powder coat washing machines, they they did a great job, left it with them for 1 day and cost £25 Theres a place near my house that does powder coating. Is it possible to get a frame powder coated with a glossy finish? Quote Link to comment Share on other sites More sharing options...
Janson Posted March 25, 2006 Report Share Posted March 25, 2006 yep.go talk to them Quote Link to comment Share on other sites More sharing options...
