Could Someone Please Tell Me How To Bleed My Brakes?
C_T_C monty
Hello to all,
I have heard that if you bleed your Maguras with water it is suppose to make them work better.
I know how to bleed my brakes but I ran into a spot of bother.
i bleed my front brake first and everything was fine, then i started to bleed my rear brake and it just stopped working :$ :( .
So i swap the levers to see if the rear lever was broken but the lever was fine and the front lever (that was on the rear set-up) didn't work.
I thought it might be the Cylinders on the so i swap them round and theirs was nothing wrong with the cylinders.
So i think it might be the tubing because the cylinders and the levers work on the front hose which is shorter than the rear one.
Any help is widely Appreciated.
Thanks, Charlie (Y)
