rhythm_101 Posted March 22, 2006 Report Share Posted March 22, 2006 hi, i know that you can use other types of fluids in HS33 (water, veggie oil etc..) but is it possible to use anything other than the magura mineral oil, in a louise FR disc? as its a bit of a shit to come by over here! any help would be greatly appreciated.. Quote Link to comment Share on other sites More sharing options...
mat hudson Posted March 22, 2006 Report Share Posted March 22, 2006 nope, just mineral oil. you can use water but it will boil i suppose baby oil coulc work. or apparentley you can use citroen somthing or other fluid. Quote Link to comment Share on other sites More sharing options...
DAB Posted March 22, 2006 Report Share Posted March 22, 2006 Only use magura blood in maguras.... I no you'll get repliles saying "use water it's great" but don't... the best stuff to use is magura blood thats it.. Quote Link to comment Share on other sites More sharing options...
mat hudson Posted March 22, 2006 Report Share Posted March 22, 2006 its a disk dude, and water is perfectley fine in normal maggies. Quote Link to comment Share on other sites More sharing options...
ScotchDave Posted March 22, 2006 Report Share Posted March 22, 2006 If you want to try baby oil, I recomend checking its boiling point. I have no idea what it is, most likely fairly high, but just check anyway. Quote Link to comment Share on other sites More sharing options...
shovel Posted March 22, 2006 Report Share Posted March 22, 2006 mineral oil only in magura discs, any other alternatives will mess it updoesn't have to be magura stuff though, any mineral oil should do Quote Link to comment Share on other sites More sharing options...
anzo Posted March 22, 2006 Report Share Posted March 22, 2006 Baby-oil is water based. Just go to the garage and get some DOT 4 fluid, its about 3 quid or so for a small bottle. Quote Link to comment Share on other sites More sharing options...
rhythm_101 Posted March 22, 2006 Author Report Share Posted March 22, 2006 (edited) AHAA i knew there was something...i'll get some citroen oil when i've got some free time!thanks alooot Baby-oil is water based. Just go to the garage and get some DOT 4 fluid, its about 3 quid or so for a small bottle.no, DOT 4/5 will perish the seals, thats why its says MINERAL oil only.... Edited March 22, 2006 by rhythm_101 Quote Link to comment Share on other sites More sharing options...
ScotchDave Posted March 22, 2006 Report Share Posted March 22, 2006 It'll have to be car mineral oil then. Quote Link to comment Share on other sites More sharing options...
Mooore! Posted March 22, 2006 Report Share Posted March 22, 2006 someone mentioned using dot 4 or 5.1. don't do it, it f's the seals & hoses. Citroes suspension oil as used in the bx or whatever it was called is spot on. And when i bought it, it was the same price for 2 litres of that as it was for 100ml of blood oil. Quote Link to comment Share on other sites More sharing options...
anzo Posted March 22, 2006 Report Share Posted March 22, 2006 someone mentioned using dot 4 or 5.1. don't do it, it f's the seals & hoses.Opps, sorry. Didnt realise you couldn't use brake fluid :$ Quote Link to comment Share on other sites More sharing options...
