Janson Posted March 20, 2006 Report Share Posted March 20, 2006 hey,my king keeps coming loose and i want to make it stop!its a classic with hd axle. I do up the collar as hard as i can with my fingers, then tighten the 3/32" bolt as hard as i dare to, but the b*****d comes loose every 5 seconds!help! Quote Link to comment Share on other sites More sharing options...
Hobnobs Posted March 20, 2006 Report Share Posted March 20, 2006 (edited) Is the bolt coming loose? If so, locktite it? Or just give it some pasty. Edited March 20, 2006 by Hobnobs Quote Link to comment Share on other sites More sharing options...
ScotchDave Posted March 20, 2006 Report Share Posted March 20, 2006 Mine does this too, mines an iso disc but same axle and bolts. Quote Link to comment Share on other sites More sharing options...
Janson Posted March 20, 2006 Author Report Share Posted March 20, 2006 I think i will give the bearing preloader thingy a bit of force with a screwdriver or something.. clean it off before so it wont slip.bearing play = weird noises! Quote Link to comment Share on other sites More sharing options...
dave33 Posted March 20, 2006 Report Share Posted March 20, 2006 when you do the small ellen key up does the collar close up ? Quote Link to comment Share on other sites More sharing options...
James_Porter Posted March 20, 2006 Report Share Posted March 20, 2006 dont do do the collor up to tight though cause it will make the hub skip. Quote Link to comment Share on other sites More sharing options...
Janson Posted March 20, 2006 Author Report Share Posted March 20, 2006 so should there be any play in the bearing at all? ive done it up a bit tighter than before, should go ride tomorrow to see if it works loose. hopefully not! Quote Link to comment Share on other sites More sharing options...
Hobnobs Posted March 20, 2006 Report Share Posted March 20, 2006 There shouldnt be any play, but you dont wanna overtighten the collar itself. The bolt to hold it in place can be as tight as you want (up to a point obviously) Quote Link to comment Share on other sites More sharing options...
dave33 Posted March 20, 2006 Report Share Posted March 20, 2006 sounds like the threads on the axle or collar are worn after comming lose all the time Quote Link to comment Share on other sites More sharing options...
Janson Posted March 20, 2006 Author Report Share Posted March 20, 2006 i'll give it a week. something in me is telling me everything is fine, i'm just overreacting. will bump if it keeps being broked, Quote Link to comment Share on other sites More sharing options...
nb88 Posted March 20, 2006 Report Share Posted March 20, 2006 When my standard axle cone kept coming loose i just cleaned the whole hub out and it stopped it says in the manual to not loctite it. Quote Link to comment Share on other sites More sharing options...
Greetings Posted March 21, 2006 Report Share Posted March 21, 2006 My BMX hub does exactly the same, it's driving me up the wall This is apparently due to it being fairly new. Should stop after it's bed in though.How long have you had it? Quote Link to comment Share on other sites More sharing options...
dave33 Posted March 21, 2006 Report Share Posted March 21, 2006 im pretty sure jansons had his for ages the bed in peroid is 60 hours of use Quote Link to comment Share on other sites More sharing options...
MrSuave Posted March 21, 2006 Report Share Posted March 21, 2006 my first king did this and theres a very simple fix which was shown to me by the top mechanic at evolution imports/brompley bike co who are the UK importor for king stuff. basically you need to overtighten the cone on the non drive side a touch so that when it is all back together the bearings bind slightly then once ridden, the bearings become free spinning and the cone doesn't come loose. no need for loctite or such.this is taken from the king website, i draw your attention to item 4 :Rear hub adjustmentThe following instructions assume that the drive shell is facing to the right:1. Insert 5 mm hex wrenches into both ends of the axle assembly.2. Hold left hand stationary and turn right hand counterclockwise 1/4 turn untilthe assembly is loose.3. Hold hex wrenches stationary and adjust bearing preload with the adjustingcone. You may use the hub cone adjusting tool if necessary.4. Advance adjusting cone until it contacts bearing. The rear hub takes a slightlyhigher amount of preload than “no play”, since some settling may occur whileriding.5. Once preload is set, tighten axle assembly together to 100 inch-pounds.6. Check adjustment by clamping wheel into frame with quick-release. Ride for5-10 minutes, check for play or binding, and readjust as necessary. Double9check adjustment after the first 5-10 miles of riding. hope this helps. Tommo. Quote Link to comment Share on other sites More sharing options...
mat hudson Posted March 21, 2006 Report Share Posted March 21, 2006 someone thinks mr janson will want to go back to his acs claw before long Quote Link to comment Share on other sites More sharing options...
Janson Posted March 21, 2006 Author Report Share Posted March 21, 2006 to be honest, i dont think ive ridden 50 hours on it.ill go for a cruise later, to see if it loosens. thanks for the help people, i really want the bugger to work, as ive lost all confidence in the hub.and mat, i'd go back if someone made decent fixed hubs. Quote Link to comment Share on other sites More sharing options...
mat hudson Posted March 22, 2006 Report Share Posted March 22, 2006 DMR f**kING ROCK!!! i'v had my dmr the bestpart of 2 years i think. no problems whatsoever. i'm getting a new wheel soon too so i think its going up for sale. Quote Link to comment Share on other sites More sharing options...
