on that? u must be joking Posted March 18, 2006 Report Share Posted March 18, 2006 On my laptop which runs windows 2000 I have installed bit torrent and use zone alarm free firewall. There doesn't seem to be anywhere in the free version to set up ports for bittorrent to use and so i am unable to download using bittorrent on it. Can anyone suggest another free firewall which will allow me to do this, or a work around for zone alarm?Cheers,Andy Quote Link to comment Share on other sites More sharing options...
Tomm Posted March 18, 2006 Report Share Posted March 18, 2006 The last time I used Zonealarm (age ago) there were loads of options for exceptions etc. I can't believe that they have made it worse since then. Are you sure it's Zonealarm that is causing the problems? Quote Link to comment Share on other sites More sharing options...
Greetings Posted March 18, 2006 Report Share Posted March 18, 2006 I used Zone Alarm with BitTorrent and there were no problems whatsoever. Go through the 'programs' menu and make sure that it isn't blocked as a client nor server. Don't think that you need to mess arround with the ports, this shouldn't happen. Quote Link to comment Share on other sites More sharing options...
UrbanPoet Posted March 18, 2006 Report Share Posted March 18, 2006 I could never configure ports with Zone Alarm; there just doesn't seem to be an option! Eventually I just set up a hardware firewall so I could configure it fully.Bittorrent, at least when using BitComet, you also need to make sure that a listening port is set up (6881) for incoming connections and shizzle. I don't know of any good software firewalls (are there any?), XP Firewall is adequate, but not an option for you unless you want to upgrade to XP. Quote Link to comment Share on other sites More sharing options...
