Trek Bruiser Trials Conversion
Howdy, have a bruiser one from a while back, pretty much standard apart from a few pointless bits.
Am thinking of converting it so i can start to ride trials! Would this frame be ok for it? Its not THAT heavy but what do you guys reckon? Should i even bother doing it but i have - £ at the mo so cant aford to buy a proper trials frame.
Help would be wiked, Ta! Rich :turned:
itll be ok as a starter, but the geo is set up for a 100mm fork, so the bb will be quite low
maybe try some longer rigids (trailblades, charge, identity) to keep the bb up and the general feel of the bike good :)
if you have got it, you may as well use it, then save for a decent frame once you have killed this one
alternatively, if this one is in good condtion you could be lookin at about 40-60quid for it secondhand, so maybe sell it and put some more pennies into something a little better for trials? perhaps a secondhand zebdi, base or echo :) you can pick up some nice trials frame son here from 60-100 thatll last good while, and be a totally different league ride wise to the bruiser (Y)
