Magura Tpa
The lemonade man
Hello, This morning I tried to set up my brake, just fiddling about with the TPA. So I got it about right and then pulled the lever and <click> I then tried to turn the TPA and it's jammed. I can just about get it round half way with a screwdriver but it doesn't seem to do much. Also, problem no. 2, one of the pads goes further and sooner than the other (sorry don't know how to describe it), I'm presuming this is something to do with the crossover cable as it works better on the side where the main cable goes into the caliper.
Hope that all makes sense. Anyone had this problem before?
(this lot assuming its an '05 mag) Try turning the TPA around, so its using threads that havent been mangled, or put a tap through it if you have one, its M6. Or last resort, fire me a PM and i'll sort you out with an alloy replacement.
