Dan6061 Posted March 15, 2006 Report Share Posted March 15, 2006 Right then, Just wondered if any of you guys could help me? Yesterday, I had my rear Magura working fine, then I started playing with the little grub screw to pull the lever closer to the bars, just to see what it was like, then un-did it. Becuase I didn't like it. And the brake felt shit. It felt really spongey, even with my Booster, and completely different to before. I've had many attempts to bleed it, I've cleaned the cylinders out with WD40, and flushed all the black crap out, and built it all up and bled it. Still spongey. I've repeated this about 3 times now. The cylinders weren't responding very quickly at first, but they seem ok now. But it still feels spongey. Is it fooked? If so, will it be just a new pair of cylinders I'll be needing? Or a whole new brake? It's water bled by the way, But I might change that to oil, if water is the reason this has happened. I don't know exactly how old the brake is, as I bought it second hand off eBay. And It was oil bled before. I'm guessing that they're quite old though... It's annoying, missed a lovely days riding faffing around with my brake. Got my new bubblegum pads ont front, and they're lovely and grabby! Just can't ride without a rear brake. Help Quote Link to comment Share on other sites More sharing options...
joewhite Posted March 15, 2006 Report Share Posted March 15, 2006 heyare you sure you put the grub screw back as you found it as that may be the problem im not sure but just have a play awith that parthope i helpedjoe Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted March 15, 2006 Author Report Share Posted March 15, 2006 heyare you sure you put the grub screw back as you found it as that may be the problem im not sure but just have a play awith that parthope i helpedjoe The grub screw shouldn't make the brake shit anyway. I'm conmfused by it. But I ordered some new cylinders off CRC, As mine looked pretty fooked anyway. Just hoping that'll sort it. Bloody bike, nothing but trouble! Quote Link to comment Share on other sites More sharing options...
Ben Cox Posted March 15, 2006 Report Share Posted March 15, 2006 send me the brake and ill bleed it for you, my latest bleed is a beastBen Quote Link to comment Share on other sites More sharing options...
Deonn h Posted March 15, 2006 Report Share Posted March 15, 2006 Did you loosen the tpa before bleeding it. Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted March 15, 2006 Author Report Share Posted March 15, 2006 Did you loosen the tpa before bleeding it. Yep. Quote Link to comment Share on other sites More sharing options...
