The lemonade man Posted March 15, 2006 Report Share Posted March 15, 2006 Ok, never had this problem before but I just bought a new wheel and my chain seems as if it needs shorter links to fit on it.Is this a common problem and are there any "short link chains" that would make it work and still fit on the front chainring? Quote Link to comment Share on other sites More sharing options...
Guest Posted March 15, 2006 Report Share Posted March 15, 2006 You should replace the chain and sprocket at the same time to avoid that sorta thing. It's cos they wear with each other. Quote Link to comment Share on other sites More sharing options...
The lemonade man Posted March 15, 2006 Author Report Share Posted March 15, 2006 So, what do I do? New chain or new sprocket? The chain is pretty new, but to be honest I don't think it's just wear as the sproclet looks pretty new and the chain (just from what goes round the sprocket) looks as if it should be about a link shorter in total. Bit annoying this Quote Link to comment Share on other sites More sharing options...
Guest Posted March 15, 2006 Report Share Posted March 15, 2006 I'm not sure I understand your problem, you might need to simply remove a link.Is it each individual link is too big? Are you still using the same Gear Ratio? Quote Link to comment Share on other sites More sharing options...
The lemonade man Posted March 15, 2006 Author Report Share Posted March 15, 2006 Each individual link is too big, have tried about 3 different chains.I've not got a gear ratio at the moment as I've got no cranks on it Quote Link to comment Share on other sites More sharing options...
Guest Posted March 15, 2006 Report Share Posted March 15, 2006 Beat's me. Quote Link to comment Share on other sites More sharing options...
sUm Posted March 15, 2006 Report Share Posted March 15, 2006 I'm no expert on the matter but it sounds as though you're not using the right chain. Some chains are designed to work with very small cogs (11t or less). I wish I could give you more information but I do know that some chains cannot be run on very small cogs. Quote Link to comment Share on other sites More sharing options...
Ben Cox Posted March 15, 2006 Report Share Posted March 15, 2006 get the khe collapse chain, that should be good as its designed to go round smaaall cogs Ben Quote Link to comment Share on other sites More sharing options...
The lemonade man Posted March 16, 2006 Author Report Share Posted March 16, 2006 Thanks guys, I'll take it to my LBS and see if they've got one to fit Quote Link to comment Share on other sites More sharing options...
JIX Posted March 16, 2006 Report Share Posted March 16, 2006 Could be your sprocket is designed for a wider chain. The difference between 2/32 and 1/16 or what ever chains and chainrings are Quote Link to comment Share on other sites More sharing options...
