cheese_cake Posted March 14, 2006 Report Share Posted March 14, 2006 i got a white industries eno freewheel about 3 days ago suddenly after a few big statics its started clicking when im pedaling its concerning as there pricy can anyone help me find out what it is. Quote Link to comment Share on other sites More sharing options...
cvtrial Posted March 14, 2006 Report Share Posted March 14, 2006 When you're pedaling real hard, it jumps over one of the pawls inside the freewheel, it's normal, but not if it happens everytime you pedal a bit hard!Hope I helped you Quote Link to comment Share on other sites More sharing options...
BeNNy Posted March 14, 2006 Report Share Posted March 14, 2006 Maybe the lock ring needs tightening? I've heard that ENO's need tightening once, then wont need tightening again Or maybe it just needs bedding in? or something? Benny. Quote Link to comment Share on other sites More sharing options...
joe_eyre Posted March 14, 2006 Report Share Posted March 14, 2006 (edited) hi therei had an eno freewheel for a while and i had the same problem. what i found the main problem to be is the freewheel coming loose on the side. to sold the problem take a dot punch and a small hammer and tap the nut on the side of the freewheel until it becomes tight.hope this helps Edited March 14, 2006 by joe_eyre Quote Link to comment Share on other sites More sharing options...
Jaffacakes Posted March 14, 2006 Report Share Posted March 14, 2006 Maybe the lock ring needs tightening? I've heard that ENO's need tightening once, then wont need tightening again Or maybe it just needs bedding in? or something? Benny.I've had to tighten mine about 3 times .Anyway all will be ansered in this thread. Link Quote Link to comment Share on other sites More sharing options...
JT! Posted March 14, 2006 Report Share Posted March 14, 2006 Are we talking about the freewheel completely skipping? Or just clicks that don't really hinder the performnce.If it's full on skipping, see the link above.If it's just making little clicks as you pedal, it's nothing to worry about. It's more likely to be your bottom braket. As when a freewheel is engaged, it's effectivly a fixed cog and there's no reaon it'd click. You'll probably find the noise will go away after a few days. Quote Link to comment Share on other sites More sharing options...
liam-pantera Posted March 15, 2006 Report Share Posted March 15, 2006 ive took mine to bits before cleaned it out with wd40 and tightend it up and it works sound now there abit tempramental i think the best soloution is not to get one in the first place profile and just acs freewheels are much better and cheaper in the long run Quote Link to comment Share on other sites More sharing options...
joe_eyre Posted March 15, 2006 Report Share Posted March 15, 2006 hi thereOh you mean one of those Acs claws that you snapped baseguy cheers joe Quote Link to comment Share on other sites More sharing options...
poopipe Posted March 16, 2006 Report Share Posted March 16, 2006 (edited) acs freewheels are much better and cheaper in the long runnononononononoacs freewheels are not good. they come undone, they wobble, they click and they feel like they're made of plastic. they also only have 36 epseno freewheels are very good. they don't come undone, they don't wobble, they feel like they're made of metal. they have 72 epsIf your eno isn't good you either aren't maintaining it properly or you've got a broken one that you should have replaced under warranty.in answer to the original question -check onzaboymarks official eno thread - i think its in the FAQ section of trials chatAll you probably need to do is give it a good flush out with GT85 or similar and then run it with a bit of lovely thin lube. The thick blue goo squeezes out of the bearings as it beds in and can cause your pawls to slip when they should be engaging. Mines been running for months without a hint of a funny noise after I last flushed it out Edited March 16, 2006 by poopipe Quote Link to comment Share on other sites More sharing options...
