The Shake Between The Forks And The Frame
earsy104
does it matter how much i tighten it...as it looks like the bolt just keeps going....doesnt get tight tight but the shaking has stopped...so does it never stop tightening?...if you get what i mean??
If you tighten to much, your swinging could be damaged by going slowly around. Try to just tight to it stops, not use all your muscels and push around after it has stoped! :S
hmm dont think ive got one at the moment but if i dont put to much pressure on the front end it should be ok for a week or so shoulndt it...... :( ......it has stopped most of the shaking.....
your life! only like 50p??? pop in you local bike shop or something
undo you top nut the bit on top of the stem 5mm needed anti clockwise
then do the same on your stem either 1-3 bolts
then you can just lift your bars up
wack the spacer on top of your steerer tube
put bars and stem back on
make sure you tighten the top bit perpendicual to steerer tube 1st
then tighten up bits to you stem
if you get me
