Adrian Posted March 8, 2006 Report Share Posted March 8, 2006 hey ive searched there wasnt enough info for me... so what is the best brake set up ever for hs33best pads hard or light grindbest brace other pads ive triede.t.c and please dont just say what your running at the moment....thanks alot. adrian Quote Link to comment Share on other sites More sharing options...
watto Posted March 8, 2006 Report Share Posted March 8, 2006 harsh grind plazmatic crm padswater bleedbraided hose echo team booster Quote Link to comment Share on other sites More sharing options...
mini Posted March 8, 2006 Report Share Posted March 8, 2006 Hi, you should try using water as the fluid in your brakes. You should also clean out the cables. The problem might also be that your frame is flexing, the solution for this is to get a booster or a new stronger frame. Another posability is that your pads might be squint.Personally i run coust'sink pads on a CNC backing with a harsh grind.Thanks and i hope that i have helped you .From Stuart Quote Link to comment Share on other sites More sharing options...
1337 Trials Posted March 8, 2006 Report Share Posted March 8, 2006 Can have you have a resnoble brake with just echo booster light grind and coust pads??? Quote Link to comment Share on other sites More sharing options...
Jaffacakes Posted March 8, 2006 Report Share Posted March 8, 2006 harsh grind plazmatic crm padswater bleedbraided hose echo team boosterThe plazmatics will be gone in a day .Get a really light grind.plazmatic CRMwater bleedand a booster Quote Link to comment Share on other sites More sharing options...
Ewannnn Posted March 8, 2006 Report Share Posted March 8, 2006 light grindkoxx bloxx red or yellowwater fluidtoxsin brake booster Quote Link to comment Share on other sites More sharing options...
flipkickbs Posted March 8, 2006 Report Share Posted March 8, 2006 (edited) Can you have a reasonable brake with just an echo booster, light grind, and coust pads??? ^^^^^^^ Yea, that would be a fairly good brake as coust pads tend to work on most grinds. Your booster will effect stiffness of the brake, but if it works then its all good! Ian Edited March 8, 2006 by flipkickbs Quote Link to comment Share on other sites More sharing options...
chrishayton Posted March 8, 2006 Report Share Posted March 8, 2006 The plazmatics will be gone in a day .Get a really light grind.plazmatic CRMwater bleedand a boosteror 4 month as mine are on a harsh grind since before xmas and they still ok and i ride alot Quote Link to comment Share on other sites More sharing options...
Bike addict Posted March 8, 2006 Report Share Posted March 8, 2006 Koxx blox brownswee bit of tarno grindecho cnc boosterHope this helped Quote Link to comment Share on other sites More sharing options...
