Luke Drewery Posted March 8, 2006 Report Share Posted March 8, 2006 (edited) I use;FRONT-Avid ball bearing 7 disc brake with an XTR lever, Fibrax cable and standard Avid pads. Works awesome.REAR-05 Hs33 lever on a pair of very old calipers, all black with Unex braided hosing and Heatsink coust pads on a harsh grind, no booster as my Czar frame is stiff enough for me. Edited March 8, 2006 by scunnytrials Quote Link to comment Share on other sites More sharing options...
C_T_C monty Posted March 8, 2006 Report Share Posted March 8, 2006 Magura HS33 05 front and rearStock black pads on the front, Blue Heatsinks on the rearGrind on both wheelsMagura brake Fluid (don't no what it's called ) Quote Link to comment Share on other sites More sharing options...
wolfie Posted March 8, 2006 Report Share Posted March 8, 2006 Front brake: Hope Mono Trial, 160 mm rotor.Rear brake: Magura HS33 04, Zoo pads on a smooth rim with a little tar, and factory bleed. Quote Link to comment Share on other sites More sharing options...
poopipe Posted March 8, 2006 Report Share Posted March 8, 2006 Front brake: Magura Louise FR 05, rotor customised with dirty great scratch - makes excellent pinging noise under heavy braking.Rear brake: Magura HS33 05, plaz crms, tar Quote Link to comment Share on other sites More sharing options...
Andy King Posted March 8, 2006 Report Share Posted March 8, 2006 OLD SKOOL Magura 01's!!!!Plas padsno grind (tar is the way ahead)Magura Royal Bloodwhats the deal with water and anti freeze?? is that just a skin flints way of bleeding a brake or is it good??andy Quote Link to comment Share on other sites More sharing options...
wayneone Posted March 8, 2006 Report Share Posted March 8, 2006 2004 levers with a rear 04 slave set and a front 05 slave set.Milehams clutch oil in both.Rear rim has a light/medium grind, front is smooth.Zoo! pads rear and koxx bloxx yellows front.Magura booster on front and onza carbon on the rear. Quote Link to comment Share on other sites More sharing options...
geraldo453 Posted March 8, 2006 Report Share Posted March 8, 2006 1.magura hs332.plazmatic spanish flys pads (very soon)3. i flaped my rim, not grinded it, grindin cuts into your rim, i just flaped myne, its BEEPP!! amazingoil in both brakes Quote Link to comment Share on other sites More sharing options...
gazasmith Posted March 8, 2006 Report Share Posted March 8, 2006 i run a rear magura standed bleed with zoo pads on a none grind rim with a bit of tar i find it works a treet had no problems with this apart from in the wet a bit of damp gets on the rim you have had it [no back brake]on the front i rum a hope mono trials disc with im find ok not a graby as a magura for me Quote Link to comment Share on other sites More sharing options...
Heatsink Posted March 8, 2006 Report Share Posted March 8, 2006 Front: Heatsink Red Vees + unbranded arms and Avid lever - simple but effective!Rear: Heatsink CNCed magura backing with red pads + Heatsink CNCed booster - Uber pimp!I keep saying I'll try a rear Vee set-up one day, but I'm really happy with my brakes and have no time to fiddle too much with my bike! Quote Link to comment Share on other sites More sharing options...
DAB Posted March 9, 2006 Report Share Posted March 9, 2006 03 hs33's race lines Monty citrus padsScuft rear x-lite rimSmooth front 517 cd rim4bolt rear mount leeson booster (2bolt carbon)Race line D font booster on evo montsHope mini on front for those realy s##t muddy comps.. Quote Link to comment Share on other sites More sharing options...
joshywa Posted March 9, 2006 Report Share Posted March 9, 2006 (edited) By the end of next week mine will be something like:FRONTAvid BB7 caliper 160mmAvid polygon rotorOddesy linear slik cablesAvid speed dial 7 leverAvid standard padsREARTry-All rim 47mm wide (smooth and a litle tar)04 maguraMagura cnc lever bladeMJ cycles red hosingMonty compensatorMagura standard 4 bolt mountsHeatsink cnc backings with red padsEcho 4 bolt booster (thin one not the control one)Magura royal bloodGod i'm sad for being so detailed about my brakes joshywa Edited March 9, 2006 by joshywa Quote Link to comment Share on other sites More sharing options...
Biff... Posted March 9, 2006 Report Share Posted March 9, 2006 Avid 203mm disk brake on front standard pads xtr lever etc04 maggie rearmajic pads (fooking awsome)grind on rear drilled ronnie rimwarter bleedmy brakes are fooking amazing. Quote Link to comment Share on other sites More sharing options...
ben_travis Posted March 9, 2006 Report Share Posted March 9, 2006 1. magura 05 brakes2. Grind on both wheels3. heatsink reds up front - awesome and hardly wear / CNC backings with coust pads ont rear (even better with a decent grind)4. water and die icer Quote Link to comment Share on other sites More sharing options...
Jez Posted March 9, 2006 Report Share Posted March 9, 2006 1. what kind of brake - avid SD72. grind or no grind - nope3. the pads you run - heatsink red4.Whats in your brakes. - cables Quote Link to comment Share on other sites More sharing options...
Ben Geary Posted March 9, 2006 Report Share Posted March 9, 2006 Front:XTR front leverAvid ultimate armsCheap avid padsCheap cableRear:04 HS33Ceramic rim (soon to be a ronnie in a few days)Tensile bubble gum padsWater bleedStandard magura booster. Quote Link to comment Share on other sites More sharing options...
