Your Brakes
mr_chisholm
Hey,
I was Just wondering how all you guys have your brakes set up?
here's what i mean:
1. what kind of brake - magura 05 \ 04 or disc
2. grind or no grind
3. the pads you run
4.Whats in your brakes.
my brake :
1. magura 05 brakes
2. Grind on both wheels
3. Koxx reds
4. water and die icer
If you feel any more topics need added please feel free to write them down!!
Cheers
jaf :deej:
Edited by mr_chisholm
Hi, this is my brakes spec :
1. Magura 04 brakes
3. Rear:Coust sink CNC bakings. Front: Heatsink honigs
4. Water and di-icer
5. Booster rear: R and B
6. Everything else is standard
Thanks from Stuart (Y)
Edited by mini
1. Magura 05 rear, try-all disc front
2. Worn grind on rear ( so currently using tar :( )
3. Koxx browns on rear, whatever pads that come on the try-all front
4. Both bled with oil
5. RB design booster
Cheers David.
Edited by David20
1. what kind of brake - Rear- 2004 HS33 silver with Water bleed, Plaz CRM
Front - 2004 HS33 Silver with water bleed, Koxx Blox Browns
2. grind or no grind - Front's recently had a fresh grind, rear has a worn one
3. the pads you run - Plaz CRM rear, Koxx browns front.
4.Whats in your brake - Water.
front 1. avid speed dial 7 lever
2. avid bb7 160mm
3.fibrax cables and standard avid pads
rear 1. shimano XT calipers (Y)
2. avid speed dial 7 lever
3. BBB soft compound pads
4. grind
5. fibrax cable again and my vbrake is set up correctly so it actualy works unlike a lot of vee's. personal preference though i like them.
