How To Front Touch Properly
on-a-mission
I tried doing it that way but can't. i can't manage to stamp the pedals as the front wheel hits.
My method is pedal like a b*****d, coast for a bit bunny hop and aim to hit the front wheel about 2-3 inches under the top of the wall. I then get bounced higher and all i need to do is compress my legs loads. I've managed about 45 inches like this. usually do about 41-43 though comfortably.
Simply keep on practicing and you will figure it out. There is no secret, all you have to do is try it and you will eventually be able to do it. (Y)
I usually do it with two crank turns, you just need to find the right distance away from the object. Start with your strong foot forward, and just don't stop pedaling. Lift up on the last half turn. Boom hit your front wheel and should sail up nicely.
Alex
