Bolt Snapped In Frame, Few Questions
Gaz M
Right my bolt snapped both of them and ive drilled a hole and im going to buy some stud extractors tomo with the left handed thread to get them out but neither holes are completely centred, just wondering if it will stil work, also im pretty sure ive nipped a bit of my thread out, only a fraction but im just wondering if it will still be alright? thanks for the help gaz.
Bolt 1
IPB Image
Bolt 2
IPB Image
i suggest u......do what i said
Drill the small 2mm hole as close to the center of the bolt as u can *center punch, a good idea!*
then, using the bolt/stud extractors drive them into the hole. As they are lefthand thread once they lock into the hold (they are on a taper so eventually will) then keep driving and it will bring the bolt out
Top Tip! - lightly warm the aluminiuim frame as to increase its size and will bring the bolt out easier
Cheerz
Sexy ;)
