skye_trials Posted February 24, 2006 Report Share Posted February 24, 2006 Hi, i just burst my magura hs33, it is the cross over that is burst and i am not sure how to put more pipe on. I have tried before and not managed so i was wondering how it is done also what should i bleed it with again.Thanks in advance Allen Quote Link to comment Share on other sites More sharing options...
nmt_oli Posted February 24, 2006 Report Share Posted February 24, 2006 If you get hold of the service kit it will be much easier- that comes with spare hose, lots of connectors and fittings, a bleed kit, and the blocks to help put fittings onto hose.The easiest way is to get the two plastic hose clamp blocks, a new length of hose, and 2 new fittings.Clamp the hose with the blocks in a vice, with about 10mm sticking up past the blocks. get a hammer, and tap the barbed fitting into the hose, repeat for other end.Screw new hose into brake, bleed as usual. Quote Link to comment Share on other sites More sharing options...
Ben Geary Posted February 24, 2006 Report Share Posted February 24, 2006 Buy some new hose then cut it to the right lengh then take the barbs of your old cross over ( these are a mission to get of) then fit them you your new cross over, screw all on then give it a bleed, bleed with water if i was you.Much better Quote Link to comment Share on other sites More sharing options...
skye_trials Posted February 24, 2006 Author Report Share Posted February 24, 2006 (edited) Thanks guys i will try and get a bleeding kit from somewhere tomorrow, thanks again Edited February 24, 2006 by skye_trials Quote Link to comment Share on other sites More sharing options...
the judge Posted February 24, 2006 Report Share Posted February 24, 2006 a bleeding kitno need to swear Quote Link to comment Share on other sites More sharing options...
skye_trials Posted February 24, 2006 Author Report Share Posted February 24, 2006 no need to swear Sorry a servicing kit. Quote Link to comment Share on other sites More sharing options...
downhill_rob2@hotmail.com Posted February 24, 2006 Report Share Posted February 24, 2006 no need to swear What a crap joke How do you mean burst? is it just split on one end? if so, just take that pipe off and cut the poped bt off, then out it back together Quote Link to comment Share on other sites More sharing options...
skye_trials Posted February 24, 2006 Author Report Share Posted February 24, 2006 What a crap joke How do you mean burst? is it just split on one end? if so, just take that pipe off and cut the poped bt off, then out it back together Yeah it was split but i have just sorted it and now can't bleed it, i will keep trying though. Quote Link to comment Share on other sites More sharing options...
Swize Posted February 24, 2006 Report Share Posted February 24, 2006 Cheep Bleed kit.Or just do the old stick it in the sink methord . Quote Link to comment Share on other sites More sharing options...
anzo Posted February 24, 2006 Report Share Posted February 24, 2006 Buy some new hose then cut it to the right lengh then take the barbs of your old cross over ( these are a mission to get of)Blow touch...melt the hose to nothing...Easy Quote Link to comment Share on other sites More sharing options...
skye_trials Posted February 24, 2006 Author Report Share Posted February 24, 2006 Blow touch...melt the hose to nothing...Easy I just cut it off with a stanley knife, only took a few seconds Quote Link to comment Share on other sites More sharing options...
anzo Posted February 24, 2006 Report Share Posted February 24, 2006 I just cut it off with a stanley knife, only took a few secondsI like fire. Quote Link to comment Share on other sites More sharing options...
skye_trials Posted February 24, 2006 Author Report Share Posted February 24, 2006 I like fire.lol i did try it with a lighter but it never worked Quote Link to comment Share on other sites More sharing options...
deanie-b Posted February 25, 2006 Report Share Posted February 25, 2006 lol i did try it with a lighter but it never worked I think a blowtorch might get slightly hotter than a lighter? Quote Link to comment Share on other sites More sharing options...
Onza Kieron Posted February 25, 2006 Report Share Posted February 25, 2006 QUOTE(deanie-b @ Feb 25 2006, 12:12 PM) ←I think a blowtorch might get slightly hotter than a lighter?LMFAO!!!!!!!!! That is the funniest thing I have read in ages, it is'nt really that funny though Quote Link to comment Share on other sites More sharing options...
deanie-b Posted February 26, 2006 Report Share Posted February 26, 2006 LMFAO!!!!!!!!! That is the funniest thing I have read in ages, it is'nt really that funny though You obviously have a piss-poor sense of humour Quote Link to comment Share on other sites More sharing options...
shovel Posted February 27, 2006 Report Share Posted February 27, 2006 i got a split in my rear crossover and just replaced it last night, best thing to do is to clamp the barb connector in a vice and chop at it with a stanly knife and then use some cable cutters and prise it off, do the same with the other connector, with two little plastic hose holders hold the new piece of hose in the vice and hammer the barb connector innot very hard to do at all Quote Link to comment Share on other sites More sharing options...
skye_trials Posted February 27, 2006 Author Report Share Posted February 27, 2006 i got a split in my rear crossover and just replaced it last night, best thing to do is to clamp the barb connector in a vice and chop at it with a stanly knife and then use some cable cutters and prise it off, do the same with the other connector, with two little plastic hose holders hold the new piece of hose in the vice and hammer the barb connector innot very hard to do at all Hi, i tried this and the new pipe just kept on turning round and slipped off easily so i heated it up, did you have a problem with it turning on the barb connector? Quote Link to comment Share on other sites More sharing options...
shovel Posted February 27, 2006 Report Share Posted February 27, 2006 i choped a heap off with the stanly knife and then gripped the sides of the barbed connector with the hose on it and pulled at it and it came off. when i hammered the barbed connector onto the new bit of hosing it was a very tight fit, gave the bike a bit of a test today and it's all goodthe new tubing will turn round a little bit on the barbed connector, quite stiffly though. . . .prob need a couple of new barbed connectors if the hose is spinning very freely Quote Link to comment Share on other sites More sharing options...
