joe parker Posted February 24, 2006 Report Share Posted February 24, 2006 hi , i was juts wonderin wat everyone thinks about the 05 and the 05 magura hs33's cause im goin to buy a set and i was juts wonderin? Quote Link to comment Share on other sites More sharing options...
Sam Oliver Posted February 24, 2006 Report Share Posted February 24, 2006 Loads of posts on this topic ! You will find people have there own opinion, mine is the 05s are slightly better, (feel nicer & tpa lasts a little longer) I would buy the 04s at the mo though because they are alot cheaper. Quote Link to comment Share on other sites More sharing options...
anzo Posted February 24, 2006 Report Share Posted February 24, 2006 (feel nicer & tpa lasts a little longer)you think so? I run an 04 lever on 05 calipers. I think the 05's are terrible designs, with the 04 you can bodge them with a bolt from your brake mounts and its even better. Cheap and cheerful and if the original TPA goes on the 04, its easily fixed unlike the 05.Personally, I'd only ever have an 05 lever if i had a metal TPA adjuster. Quote Link to comment Share on other sites More sharing options...
Sam Oliver Posted February 24, 2006 Report Share Posted February 24, 2006 Personally, I'd only ever have an 05 lever if i had a metal TPA adjuster.The 05 lever's are bodgeable too Quote Link to comment Share on other sites More sharing options...
Dan-Walker Posted February 24, 2006 Report Share Posted February 24, 2006 Personally, I'd only ever have an 05 lever if i had a metal TPA adjuster.The 05 lever's are bodgeable too how do you bodge them then.... Quote Link to comment Share on other sites More sharing options...
Dr Greenthumb Posted February 24, 2006 Report Share Posted February 24, 2006 '04/ levers are better and feel nice in my opinion. Quote Link to comment Share on other sites More sharing options...
Thurston Posted February 24, 2006 Report Share Posted February 24, 2006 05's in my opinion are far better and have a nicer feel because there shaped more to your finger.Cheers Thurston Quote Link to comment Share on other sites More sharing options...
011001000110010101110010 Posted February 24, 2006 Report Share Posted February 24, 2006 I used to love my 04 magura, and when i changed to an 05 I hated it for a while but you get used to it. They are better designed because you have to try hard to break the TPA. Quote Link to comment Share on other sites More sharing options...
nmt_oli Posted February 24, 2006 Report Share Posted February 24, 2006 I still prefer the 04 version, and if you can find an old lever blade (pre 2001 i think, not sure) they are flat (like a hope lever) rather than curved, so even more comfy, although thats personal preference.Also todge should have his fresh products lever out soon, which will fit into the 04 body, and be a bit like the RB lever- but even better! Quote Link to comment Share on other sites More sharing options...
joe parker Posted February 24, 2006 Author Report Share Posted February 24, 2006 wat could i get the hole 05 brake and then juts change the lever blade??? because i have a 04 one and i loved it but the brake went all crappy! thanksjoe Quote Link to comment Share on other sites More sharing options...
the judge Posted February 24, 2006 Report Share Posted February 24, 2006 wat could i get the hole 05 brake and then juts change the lever blade??? because i have a 04 one and i loved it but the brake went all crappy! thanksjoeNo that won't work, completely different attachment. I prefer the 05 brakes as they are more comfortable in my opinion. Quote Link to comment Share on other sites More sharing options...
theone2be Posted February 24, 2006 Report Share Posted February 24, 2006 I run 05's but i would rather 04's. They just feel a bit better don't really know why Quote Link to comment Share on other sites More sharing options...
human_furball Posted February 24, 2006 Report Share Posted February 24, 2006 I am going to get 05 but I really do not mind. All i care about is I'm getting a bike.Chris Quote Link to comment Share on other sites More sharing options...
nmt_oli Posted February 24, 2006 Report Share Posted February 24, 2006 wat could i get the hole 05 brake and then juts change the lever blade??? because i have a 04 one and i loved it but the brake went all crappy! thanksjoejust find out what is wrong with the brake- working from lever to slaves, take the brake apart, clean it, and put it back together lubing as you go, replace any parts that need replacing, and re bleed- should be good as new! Quote Link to comment Share on other sites More sharing options...
joe parker Posted February 25, 2006 Author Report Share Posted February 25, 2006 ive ordered a set of 04 hs33's from bike dock! thanks for all ur comments they really help! cheers joe Quote Link to comment Share on other sites More sharing options...
trials_man Posted February 26, 2006 Report Share Posted February 26, 2006 I'd buy the 04 ones. They are cheaper, more reliable and less likely to break. Quote Link to comment Share on other sites More sharing options...
Trials Boy Posted February 26, 2006 Report Share Posted February 26, 2006 IMO i'd say:04: Stock05: ModBut meh, its your own choice Quote Link to comment Share on other sites More sharing options...
the judge Posted February 26, 2006 Report Share Posted February 26, 2006 IMO i'd say:04: Stock05: ModJust curious, why? Quote Link to comment Share on other sites More sharing options...
Jaffacakes Posted February 26, 2006 Report Share Posted February 26, 2006 IMO i'd say:04: Stock05: ModBut meh, its your own choice What's that got to do with anything. I had a 05 lever and didn't realy mind it, The TPA broke in a few months, and after had a few goes on my mate's 04 I realised how superiour they were and came to my senses and brought one.They 05's just feel weak and flimsy like they have tried to shave to much weight off it and just made it crap. If you wan't a manly lever the 04 is the way to go . Quote Link to comment Share on other sites More sharing options...
munch8987 Posted March 2, 2006 Report Share Posted March 2, 2006 05' all the way mate.....i bought a set for my new build...and they fell much better...lever blade's alot more comfortable and the pivot point much improved...plus...u havnt got the chance of snappin the tpa off on an nasty landing Quote Link to comment Share on other sites More sharing options...
Krisboats Posted March 2, 2006 Report Share Posted March 2, 2006 05' all the way mate.....i bought a set for my new build...and they fell much better...lever blade's alot more comfortable and the pivot point much improved...plus...u havnt got the chance of snappin the tpa off on an nasty landing I've never done that, plus within 30 seconds you can whack a bolt in it and it is ten times more adjustable and reliable.The 04's are wider so fit bigger hands better, the levers are thinner and too close to the bars on the 05's (they need bending out more before they're nice) and the 05's look shit too. Quote Link to comment Share on other sites More sharing options...
joe parker Posted March 2, 2006 Author Report Share Posted March 2, 2006 What's that got to do with anything. I had a 05 lever and didn't realy mind it, The TPA broke in a few months, and after had a few goes on my mate's 04 I realised how superiour they were and came to my senses and brought one.They 05's just feel weak and flimsy like they have tried to shave to much weight off it and just made it crap. If you wan't a manly lever the 04 is the way to go .thank you some else who hates the 05 lever and the brake they're horrible i love my 04 hs33's now yay! joe Quote Link to comment Share on other sites More sharing options...
Trials Boy Posted March 2, 2006 Report Share Posted March 2, 2006 Just curious, why?Well 05 maggies seem too work better, when there both set up excellent on both mod and stock, i prefer 04 maggies on my stock, if i went to mod, i'd have 05 ones. Quote Link to comment Share on other sites More sharing options...
Jared Posted March 2, 2006 Report Share Posted March 2, 2006 I know this isnt strictly answering the question but...I had a ride of my mates T-mag which had an 05 rear maggie and to be honest i thought it was lame compared to my Cable brake.It looked like it was set up properly and that but didnt seem to hold very well,its like nearly new but its bedded in so i dont know what the problem could be.I only have tektro v's with standard (crap) pads and mine works better in everyway.Do you think he should take the pads of and have a look at them and clean them up or something.Its good until you get pretty vertical on the back wheel, it doesnt hold and you get a sore a**e for a couple of days. Quote Link to comment Share on other sites More sharing options...
anzo Posted March 2, 2006 Report Share Posted March 2, 2006 I know this isnt strictly answering the question but...I had a ride of my mates T-mag which had an 05 rear maggie and to be honest i thought it was lame compared to my Cable brake.It looked like it was set up properly and that but didnt seem to hold very well,its like nearly new but its bedded in so i dont know what the problem could be.I only have tektro v's with standard (crap) pads and mine works better in everyway.Do you think he should take the pads of and have a look at them and clean them up or something.Its good until you get pretty vertical on the back wheel, it doesnt hold and you get a sore a**e for a couple of days. Well, I hear arguements of a good set up Vee brake being just as good as a Magura. His magura will be shit for a reason...shit bleed, shit pads, shit grind, too much distance between pads and rim, too soft on TPA? Gowd knows.Maguras are shit-hot, but you need them set up perfectly to be exellent brakes, and oviously due to the abuse through trials they require a lot of looking after to keep them good.I can guarentee that your mates is set up incorrectly in one way or another, when you have a perfect magura setup, you KNOW you have a perfect magura setup. Quote Link to comment Share on other sites More sharing options...
