Chain Tensioning Issue
Greetings
Id like to set my chain to be fairly tight so it doesnt bash the frame, but I can't because something is not straight in the drivetrain and the chain loosens and tightens while pedaling.
I'd understand it if the cranks, chainring, bb and hub weren't new. The chain has no tight links. The cranks are screwed in straight and hard. Had the same problem with my old drivetrain, only it wasnt so severe. Any advice on what could be wrong?
Ive had/got the same problem, all it is that the threads are not cut propprly on the cog/freeweel theres nothing i know that can mend it :(.
Sam
Yeah same here , I was wondering if it effects the amount of power you can put out for pedal ups e.t.c ?
yes if the centre of the sprocket is not "in the centre" of the crank you will either have a slightly stronger or weaker pedalkick/up but this is only theory and i dont think anybody would realise it - the offset is no more than 1mm
if the chainrings are not straight one could use a file to shape the teeth to the right diameter
this is bloody annoying - you pay 20 pounds to get a proper chainring and you cant use it :angry::angry:
