mr kenny Posted February 21, 2006 Report Share Posted February 21, 2006 hey, ive fitted a braided hose to my maggie and the rebound on the pads is terrible i have bled them as i always have done with normal hoses so why are the pads taking a god awful time to run mack into the pistony bit??i do not want to change the lhm fluid i use cause i am still sceptical about waaater,so i'm sticking with the citreon suspension oil that they were designed for has anyone else had theis trouble?what can i do apart from a water/wd40 bleed?cheers kenny Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted February 21, 2006 Report Share Posted February 21, 2006 I have this problem with one of my cylinders.. Maybe we just have some gunk in them? Try taking it all apart, and cleaning it all out, then try again I will when I can be bothered, but mine's not as bad after a fresh bleed Quote Link to comment Share on other sites More sharing options...
ogre Posted February 21, 2006 Report Share Posted February 21, 2006 Suspension oil? Isn't that evil on seals? Quote Link to comment Share on other sites More sharing options...
mat hudson Posted February 21, 2006 Report Share Posted February 21, 2006 the hose has a smaller internal diameter so the fluid cannot move as quickley. blead with water. Quote Link to comment Share on other sites More sharing options...
mr kenny Posted February 21, 2006 Author Report Share Posted February 21, 2006 (edited) done A full strip down and rebuild last night(she said) , sorry a song hit me therei can't figure it out is it the new hoses?ogre: maguras use a mineral oil wich is citreon suspension oil or l h m same stuff just 5 quid a litre as apposed to 5 quid 50mls with a magura bottle! Edited February 21, 2006 by mr kenny Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted February 21, 2006 Report Share Posted February 21, 2006 the hose has a smaller internal diameter so the fluid cannot move as quickley. blead with water. Shame he doesn't wanna bleed with water though... Might be for the best though? or you could just sell the braided hose and use 'normal' plastic ones? Quote Link to comment Share on other sites More sharing options...
mr kenny Posted February 21, 2006 Author Report Share Posted February 21, 2006 nah braided hose looks the penguins plums on mr edd Quote Link to comment Share on other sites More sharing options...
Krisboats Posted February 21, 2006 Report Share Posted February 21, 2006 Well it looks like you're either going to have to stick with your oil and have a slow return or you can bleed it with water and have a much faster return. I've had water in my magura for over 6 months now with no problems at all, and i know theres other people who have had it in for longer.Its like mark said, magura's come with black pads but we change those to one's that will work better for trials... why is everyone so scared to do the same with what they bleed it with? There is the other option that you can take the lever off, the get some needle nose pliers and GENTLY pull the little piston out and give the spring that sits behind it a bit of a stretch... i've done this to mine and it made my brake fell much more lively. I am in no way responsible fo you f**king your magura up by being heavy handed and attacking the seals with the pliers or dropping it on the floor and standing on it . Quote Link to comment Share on other sites More sharing options...
Jaffacakes Posted February 22, 2006 Report Share Posted February 22, 2006 If you don't want to bleed it with water you could always bleed it with WD40. If you spray a load into a jar and leave it for 1-2 weeks it will seperate leaving a thick gack at the top and a nice thin oil at the bottom.Just get a serynge or a hose or anyway you can think of taping the good oil out of the bottom then bleed your break with it. It won't damage your seals and will have a nice fast spring and a good strong feel to it . Quote Link to comment Share on other sites More sharing options...
