Wireless Internet Problems
SCOTTY___
Rightiooo
I was changing the channel on my wireless router and i came across a problem,
My Laptop has a Intel Inside thingy maboby and thats what i use to connect my Router to my laptop, I was changing the channel today and i changed to Channel number 14. It after you cahnge it and confurm it, it says it will take 25Seconds for the Router to update your changes...
Now while it was updating it cut off on 11Seconds, and now the router will not pickup the Router signal reciver inside my laptop and will not connect to the router at all so i now have no internet connection.
Any ideas people in DEVISTATED :
Thanks...
A Very upset Craig :
Use a cable to connect to the router and go back into the router settings and change it back to what it was (Y)
Why were you changing channels again though, I thought you'd just got it working?
How do you mean?
I cannot even get the router to connect to the internet at all...
I was still having problems.. So i forght ide try anew channel and it broke :
Craig...
Yeah, so get an ethernet cable and plug that into the router (and the other end into the PC, obviously). Unless it's some funky wireless-only router, which would be weird. If that is that case I guess you'd have to manually reset it, there'll probably be a button to reset on there somewhere, you'll have to push it with a pin or something. Read the manual ;)
Right ive tryed the reset botton and it hasnt made any differance...
I still need to try the Ethnet cable idea but i nhavent got a spare one.. So i need to see my contacts :shifty:
I was changing it to 14 because i was still having alot of problems while gaming, " CL_FlushEntryPacket " and it was totally kicking me out of Condition Zero and coming up with " Fatal Error "!!
So as i say ive tryed the Reset button to no avail... But still need 2 try the Ethnet Cable idea..
Anyother suggestions ??
Craig... :
Ah i see, changing channel didnt fix the problem then.......hmm
If you get an ethernet cable itll definately work, you'll just be able to connect to the router through the cable and change the settings on that ip tomm gave you in the last thread.
I really dont know what to suggest to your problem on CS though :(
I can pretty much guarantee that your problem does not lie in your wireless connection. When I ping my router via my wireless, I have a response time of less than 2ms. Even if using ethernet was instant (it's not...) to the router, that's only the difference between a ping of 30 and a ping of 32ms.
You can test it though, I guess there might be something wrong with your wireless. Start - run - type "cmd", press enter - type "ping 192.168.2.1" (i think we decided that was your router's IP?) and press enter. if it's any less than 5 or even 10, then it's not a problem.
Does your connection ever drop and then reconnect? Does the little icon in the taskbar lose connection and then reconnect a couple of seconds after?
It isnt connecting to the reciver in my laptop at all...
The laptop is saying its there.. But when i go chose my wireless v networkue my wireless options it isnt there, There is 1... But there is " Defalt " connection but it doesnt work :S And when it does it says " Low Signal " and wont connect to the IP adress Tomm gav eme... And will not connect to anyother site than google... N it takes AGES for google to come up!
I will try the Ethnet Cable when i can get hold of one, As im currently running the patop like a PC with the Ethnet cable plugged into the Modem and straight to the PC..
Is there anything else i can try befor the ethnet Cable solution?
Thanks again guys..
Craig :
Also i did the CMD thingy and i got..
Ping 192.168.2.1 with 32 bytes of Data:
Request Timeout.
Request Timeout.
Request Timeout.
Request Timeout.
Ping Statistics For 192.168.2.1:
Packets Sent = 4, recived 0, loss 4 <100% Loss>
IS that cos the router isnt connected?
Craig...
Craig...
Yes. You know you can use the cable that connects your PC to the modem, to connect the PC to the router? It doesn't matter that it's then not plugged into the modem. So just do that and then go on the router setup, you can plug the internet back in when you get wireless signal. What router is it by the way?
Ive tryed unplugging the Modem and plugging the Ethernet Cable into the router and it wont connect to the internet and bring up the router options page :S
Is there anychance u Adding me to MSn and helping me out with this?
Im kinda in trouble with my parents for breaking it :$
Its a Belkin 54g router if thats anyhelp..
Craig...
nooby_doo@msn.com <--- Feel free to add n help me ^_^
You won't be able to connect to the internet, but you should be able to connect to the router 192.168.2.2.
You have got a cable running from the PC's ethernet slot to (one of) the router's LAN port(s), right? And the router is switched on? Type that address and it ought to work.
I'm not on MSN very often, if I have any free time tomorrow night I'll add you :)
:wub: :wub: :wub:
I have no words to express my gratitude!!!
Cheers Tomm!! Sound Geeeezzzzzer!!!
Still Add me to MSN though, And if i have any problems in the near future ( I KNOW I WILL :$ ) Ide be happy to accept you advice (Y)
Cheers :)
A very chuffed Craig ^_^
