Mad Bikes
Ben Jones
Thats is a great bike i started on one last easter, all the original components were good for backhops and pedal hopping off of objects. But i would urge you to get a new chainring and chain now to aviod "chain suck" to ditch the mumbo jumbo the chain gets pushed out crooked and kinks up into the frame with takes huge gulfs out of your frame! (just trust me on this one!)
Of course as you get more serious you will want to spend money on your bike, there are wise ways to spend money and un-wise. Some wise choices such as getting some nice Vee brakes, not maggies with £18 e.t.c. 2nd hand hubs, wheels and components.
I ended up snapping my Saracen on the chainstay and cracked it half the way round the headtube BUT (i didnt say this) i rode it "fairly" harsh :- but i would love another one that didnt snapp to be honest
now my bike only has stem and bars left standard on it now, oh and grips lol but i loved that bike while i had it!!!! B)
K thanks alot (Y) i must say the bash ring does look pretty naff compared to my mates...
I see what u mean bout backhops and pedal hopping...i've only be riding bout 1 month and i can stay up for ages and lurch onto/off stuff...
any idea of a good cheap bash guard?
thanks alot :)
K thanks alot :) umm m this will show u how much of a novice i am :$ ....i know for a mod peeps have there rear wheel slightly swidgy...well what is best for a stock? slighty flat? or pumped up nice and firm?
dpends on your rim really mate. i run 20 psi in my echo 2006 rim if that helps. on my maviv rims i was running 35-40 just because it rims out all the time
k im just worries about totally messing up my wheel cos sometimes if i do a jump or summit i hear it whack the wheel...
Chainring! the sprocket inside the bash ring which guides the chain round, the cranks will be fine for now
i run about 25psi however! because your a learner (if you are) then you may want to run a lower pressure to give a larger spread surface area of your tire as your rim wont get too damaged just hopping up and down
you want THAT ONE! in the 22t 4 hole version which luckily for you is in stock for £15 and a new KMC chain not a cool or anything just yet something you can run through your gears, if youve gone single speed get a kmc kool
ok cheers mate...i quite like it at a low pressure but it sometimes sorta buckles on itself...
easier to balance though :D
depends on age and build as a rough guess on the internet its hard.
im quite big built and think mods feel really ponsy, i have riddern stock since i was 15 and just prefer it. feels more beef and more power lol if you feel good on a stock while change?
i couldnt afford to change! lol
Well my saracen was fully modifyed apart from forks so i simply switched all of the components across onto my control 1085 would have prefered the shorter 1 but got the longer one but im happy!
i love it nice on the back wheel. all the components on the Saracen is shit you need to change EVERYTHING apart from bars and stems. which i have done no problems now!
frame change is good and you will see the largest change in your riding genrally!
i think we should come to a conclusion that saracen are good starter bikes...nothing else. firstly i got a team issue, then i snapped the frame...by the way the chain suck is true. then they sent me a 2.sixH frame and forks for free and i snapped that too...now i have a team urban frame and forks for free.
bad things about the saracen m-a-d.
frame.
rear shimano hub.
in fact both shimano hubs.
the way the rear mech attaches to the frame.
the rear mech itself.
good things about the saracen m-a-d.
truvativ crankset is amazing.
forks are ok i suppose.
maguras.
grips...THEY ROCK, been riding with them for nearly a year now!!!!!!!!!!!!!!!!!!
thats about it.
Clawz
