mavic Posted February 13, 2006 Report Share Posted February 13, 2006 Morning lads and girlys , Right for the past hour i have tried to get my cranks off my bottom bracket, so far i have threaded a bb tool , pulled some of thread out of my right crank( its still works though) used a hair dryer and then a blow torch. have used wd40 and axel grease these are a beast to get off.Oh and i love my bike to bits and hate marking it so no wacking the shit out of it .(Middle Burns cranks square tappered bt the way)any help darlings?.dan. Quote Link to comment Share on other sites More sharing options...
Matt_Tupman Posted February 13, 2006 Report Share Posted February 13, 2006 Rubber mallet on the back of the crank thats pretty much all you can do now without destroying the crank Quote Link to comment Share on other sites More sharing options...
Swize Posted February 13, 2006 Report Share Posted February 13, 2006 (edited) Morning lads and girlys , Right for the past hour i have tried to get my cranks off my bottom bracket, so far i have threaded a bb tool , pulled some of thread out of my right crank( its still works though) used a hair dryer and then a blow torch. have used wd40 and axel grease these are a beast to get off.Oh and i love my bike to bits and hate marking it so no wacking the shit out of it .(Middle Burns cranks square tappered bt the way)any help darlings?.dan.Take the crank bolts out ride a round a LITTLE should loosen them off then poor boling water over them should come off pretti easy with a wack from a hammer or even by hand ??SamEdit: Check the FAQ Here Edited February 13, 2006 by Swize Quote Link to comment Share on other sites More sharing options...
mavic Posted February 13, 2006 Author Report Share Posted February 13, 2006 Ah man yer i did not do a serch i should have thanks man , i have not tried the bolilong water thing yet. Quote Link to comment Share on other sites More sharing options...
Shez.sheridan Posted February 13, 2006 Report Share Posted February 13, 2006 I remember with a FSA Powerpro crank, I drilled the shit out of it as that b*stard would not budge..then a few pedal hops did the trick - depends on whether you want to keep it though I suppose.Derv.I second the rubber mallet method.. Quote Link to comment Share on other sites More sharing options...
ScotchDave Posted February 13, 2006 Report Share Posted February 13, 2006 Take off the other crank, rotate it 180 degrees and use a car jack to lever apart. Quote Link to comment Share on other sites More sharing options...
mavic Posted February 13, 2006 Author Report Share Posted February 13, 2006 Ok this actually not amusing it will not move at all . Quote Link to comment Share on other sites More sharing options...
Brian Bleech Posted February 13, 2006 Report Share Posted February 13, 2006 i know when we f**ked the start threads on tims cranks, i came up with the random idea of putting selotape on the inside of the cranks and the bb tool then went in perfect because it slid over the selotape and caught on the good threads instead. worked perfectly. though depends on how much of the threads you have f**ked. Quote Link to comment Share on other sites More sharing options...
mavic Posted February 13, 2006 Author Report Share Posted February 13, 2006 Ah nice man, not many like 1 or 2 man. . Quote Link to comment Share on other sites More sharing options...
Alun Goch Posted February 13, 2006 Report Share Posted February 13, 2006 soak it in wd40 then use a universal puller. sorted http://www.etoolcart.com/ProductImages/Ast...ic/AST-7828.jpgsomething like the above, loadsa diffrent types thoughalun Quote Link to comment Share on other sites More sharing options...
rich4130 Posted February 13, 2006 Report Share Posted February 13, 2006 I always hit my cranks off with a hammer, copper hide thingy, I pour a kettle full of boiling water over the crank, NOT bb, and just hit it, works in the end! Quote Link to comment Share on other sites More sharing options...
mavic Posted February 13, 2006 Author Report Share Posted February 13, 2006 Yyyyyyyyyyyyyyyyyyyyaaaaaaaaaaaaaaaaaaaaaaaaaaaay THEY CAME OFF, thanks for the help darlings .topic closed . Quote Link to comment Share on other sites More sharing options...
2sixstreet Posted February 13, 2006 Report Share Posted February 13, 2006 so dont leave us all in suspense - how did you do it? Quote Link to comment Share on other sites More sharing options...
mavic Posted February 13, 2006 Author Report Share Posted February 13, 2006 Well after doing all the obove i used someone else crank tool hahaha . Come off after alot of weight was put on it!. Quote Link to comment Share on other sites More sharing options...
