Moveable Vee Mounts
Ash-Kennard
could this not be an innovation?
Rebate V-adaptors:
Pair of 4-bolt clamp-on CNC alloy Brake pivots that can be positioned to fit 24 or 26” wheels. Black anodised. 3mm safety screw prevents spinning. Weight: 117g pr
RRP £ 24:99 pr
would these fit trials forks? if so these could be used to help all the 24" riders to use decent forks for a change, and would allow people who bought disc only forks to use vee mount if needed, say if you split your disc hose etc.
I'm not advertising im allowing people to see what is availiable.
Edited by ash-kennard
I'm pretty sure they're only for those forks. There's nothing to stop some innovative person coming up with some for other forks though. They ain't new though, Pace forks about 10 years ago had a similar thing. And obviously the Ashton forks have both 24 and 26 mounts :)
I'd say they havn't been mass produced because you would need to bring out a range of fitment sizes to cover all forks, there isn't a big enough market for that sort of thing regarding a business point of view.....
i think im going to go and draw some designs for these in autocad. expect to see a few designs or even actual prototypes of these for trials usage.
probably for straight blade.
