Avid Bb7
Tom Booth
At the minute i love my bb7, But the cables some crappy 2.99 thing from my local bike shop, and the levers an avid speed dial 5 (i think).
As of lat the brakes become reallly horible feeling due to the lame cable, and the brake lever blisters my finger quite badly, so Any opinions on what lever cable i should go for?
I've been looking and i think im going to go for an XTR lever, But not sure on a cable?
Looking at the odyssey slic linear, Seems quite good. I'd Love a Nokon cable, But cant justify spending 30 quid on a cable, and how do you shorten the outer on a nokon?
Cheers
Tom
I've got an XTR lever at the moment, and it doesn't really feel any better than the SD7s I used to run, except it's nowhere near as adjustable, which is annoying. Ah well, at least people think it looks cool :rolleyes:
Nah, I guess it's an OK lever, but I reckon the Avids are better.
Running a Clarks inner and outer at the moment, and it's starting to die I think, so I might change it, although my front disc is pwning at the moment. It's gone ultra nice over the past couple of days, so I don't wanna f**k it up by changing a cable or summat :P
I'm running the XTR cable it feels good. I used a nokon for a while it gave a very solid feel but i don't know of any where you can just buy the inner casing that's inside the metal parts. So when you wear it out you might have problems.
I think as long as you have a cable that does not have a coating i.e. Teflon, you can make it work pretty well with some GT85 or something similar. The coated cables seem to work ok at first but when the coating wears off it just seems to clog up the cable.
Be careful if you are spraying lube on the cable with the disc!!! I learnt that lesson... If you get some cable oilers (middleburn make some) it makes it really easy to lube your brake.
Edited by trialsy
The teflon inner can be bough from bmx shops I think, just google it.
