jakk-robbo Posted February 8, 2006 Report Share Posted February 8, 2006 if there is a propper way to grind down a rim. could someone explain how to do so please? jack Quote Link to comment Share on other sites More sharing options...
Jaffacakes Posted February 8, 2006 Report Share Posted February 8, 2006 I always get zoo! pads so I just do a light grind but anyway...Stroke down the rim in a clockwise direction going fast or slow, hard or lightly depending on what gradient of grind you want. I do it reasonably slowish and light so I get a grind that isnt very deep but is close together. Get a old rim from a bmx or kids bike or whatever it dosent mater and practice what angle you want. There is a vidio in someones signiture but I can't remember whose it is . Quote Link to comment Share on other sites More sharing options...
Dominey Posted February 8, 2006 Report Share Posted February 8, 2006 I recently grinded my rims on my bike and i used an angle grinder and have had no problems with it since,my brakes are working alot better now.Just gently get an angle grinder to your rims and go round a few times until you are happy with it. be sure not to push too hard though, you dont want to grind too much away. Quote Link to comment Share on other sites More sharing options...
Alan Posted February 8, 2006 Report Share Posted February 8, 2006 if there is a propper way to grind down a rim. could someone explain how to do so please? jackIf your going to grind your rim, And have magura black pads you may want to start looking for some different pads. be sure not to push too hard thoughYou shouldn't apply more force than the angle grinder itself usually anyway. Quote Link to comment Share on other sites More sharing options...
Guest Posted February 8, 2006 Report Share Posted February 8, 2006 If your going to grind your rim, And have magura black pads you may want to start looking for some different pads.Why? Quote Link to comment Share on other sites More sharing options...
nmt_oli Posted February 9, 2006 Report Share Posted February 9, 2006 Why? because black pads wont grip, and will just shred- i speak from experince- landed a drop and fell fell on my arse, and pads wore down half way in just one day. Quote Link to comment Share on other sites More sharing options...
flipkickbs Posted February 9, 2006 Report Share Posted February 9, 2006 Why?Because it defeats the object of grinding your rim rather than using tar. black pads on grinds do NOT work. Fact. Have a look for some decent pads (no shortage of topics to find out which ones are good), then grind your rim accordingly, i.e soft pads: light/medium grind, hard pads: harsher grind. Be sure to grind each side in opposite directions to one another though to get better braking both forwards and backwards. Quote Link to comment Share on other sites More sharing options...
Alan Posted February 9, 2006 Report Share Posted February 9, 2006 Why? Well because i was using black pads on a grind for about 2 days backwheeled a wall and smashed my back on the top of it, Because there such a soft compound. Pads like Koxx bloxx browns will do you well. Quote Link to comment Share on other sites More sharing options...
sexymike Posted February 9, 2006 Report Share Posted February 9, 2006 Because it defeats the object of grinding your rim rather than using tar. black pads on grinds do NOT work. Fact.sorry to spoil it for u but they do, not stupidly well but they doSpeak to rowan johns, he used to use (still may do) black pads on a smooth rim, no tar, and it worked seriously welllol i doubt it worked in anyform of water though Quote Link to comment Share on other sites More sharing options...
Mark W Posted February 9, 2006 Report Share Posted February 9, 2006 Rowan's needs are different to the rest of us though, not to mention Rowan's smoother than the diarhoea I fired out earlier.And that's smooth Quote Link to comment Share on other sites More sharing options...
skye_trials Posted February 9, 2006 Report Share Posted February 9, 2006 Because it defeats the object of grinding your rim rather than using tar. black pads on grinds do NOT work. Fact. Have a look for some decent pads (no shortage of topics to find out which ones are good), then grind your rim accordingly, i.e soft pads: light/medium grind, hard pads: harsher grind. Be sure to grind each side in opposite directions to one another though to get better braking both forwards and backwards.I have had a magura black pads on for about two grinds and they are still not worn so they go work, they have gripped well for me as well. The back break never slips until the grind goes and my rim is wet. Quote Link to comment Share on other sites More sharing options...
cvtrial Posted February 9, 2006 Report Share Posted February 9, 2006 Use Search, I've posted a video from Andy T's grinding. He explains very good, and you see it in real Quote Link to comment Share on other sites More sharing options...
