Hiltop Posted February 8, 2006 Report Share Posted February 8, 2006 ok so bash plate bolts both snapped in my frame after landing on a rail at a fair speed. drilled both bolts out but can see it is going to be an arse using a hellicoil on them. so basically can i keep my current cranks, these; (echo mod cranks 158) and my current sprocket; (echo)and use one of these. echo 7075 bashring. im asking because it doesnt look like there is much room on the thread of the crank for a bashring and a sprocket.cheers. Quote Link to comment Share on other sites More sharing options...
Hobnobs Posted February 8, 2006 Report Share Posted February 8, 2006 I dont think you can, pat donovan couldnt, but i cant remember if he was using a freewheel or fixed cog. Quote Link to comment Share on other sites More sharing options...
bee_ Posted February 8, 2006 Report Share Posted February 8, 2006 I'm using the same cranks and bashring with an eno, fits fine Quote Link to comment Share on other sites More sharing options...
Tom Booth Posted February 8, 2006 Report Share Posted February 8, 2006 My friends running this set up with an ACS, takes up more thread then a cog i should imagine, So I cant see why it wont work Quote Link to comment Share on other sites More sharing options...
Swize Posted February 8, 2006 Report Share Posted February 8, 2006 (edited) There is a little washer type spacer thing on there you will have to take that off once you get the cog off. Then yes you should be able to the cranks are designed to be run with a bash like that. Also Dan-Ko runs one with an acs and same bash so you should be fine. Edited February 8, 2006 by Swize Quote Link to comment Share on other sites More sharing options...
Hiltop Posted February 8, 2006 Author Report Share Posted February 8, 2006 thank you people you just saved me a lot of arsing about Quote Link to comment Share on other sites More sharing options...
