ian Posted February 6, 2006 Report Share Posted February 6, 2006 (edited) hi there,i have been thinking about this for a while now, i was wondering if i got the v-adapters for my python so i could run a v-brake what would it be like? i have seen on heatsink bikes website that they are now selling the v-brake pad backings with the notoriously good coustelier pad material in them. so do these pads work aswell in a v-brake as on a maggy? and i take it the v-brake can be run on a grind?and what are the benefits of a v-brake on the back?cheers ian Edited February 6, 2006 by ian Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted February 6, 2006 Report Share Posted February 6, 2006 Depends on the set up you go for really. You won't get as much power from a V as you would a Magura, but would still work well if you got the right bits. Quote Link to comment Share on other sites More sharing options...
ding_dong Posted February 6, 2006 Report Share Posted February 6, 2006 All I know (in relation to your question) is that you can run a grind with a v brake, and also don't pay the £20 for the adaptors as i can sell you some, pm me you msn addi if you are interesed?? Quote Link to comment Share on other sites More sharing options...
Janson Posted February 6, 2006 Report Share Posted February 6, 2006 a vee brake can be more or less powerful than a magura. a vee is NOT worse than the maggie.coust material is awesome in whatever brake you put it. a coust vee brake with heatsink backings and adapters will be really good if you take your time setting it up, using good cable and good parts. don't skimp.though i've heard it's harder to get a good vee setup on a mod than a stock, due to massively wide tyres and chain tension adjustments via wheel movement. Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted February 6, 2006 Report Share Posted February 6, 2006 i ran a avid ultimate/deore/sd7 on my old monty and it was stupidly good, i had no troubles with setup either, you will however need to run a slimish rim to keep the v brake arms at the correct angle, i found a alex dx32 to be perfect in mine Quote Link to comment Share on other sites More sharing options...
ian Posted February 6, 2006 Author Report Share Posted February 6, 2006 All I know (in relation to your question) is that you can run a grind with a v brake, and also don't pay the £20 for the adaptors as i can sell you some, pm me you msn addi if you are interesed??ok ill add you,and there is an xtr v-brake in for sale wanted im after lol,and it would be using a sram 5.0 lever which is lovely and powerful, but im sure ill be able to set it up nicely with a little help from somebody i work with (my boss, i work in a bike shop lol)i just fancy a change and have heard mixed opinions about them Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted February 6, 2006 Report Share Posted February 6, 2006 a vee is NOT worse than the maggie.You cant really generalise though. The vast majority of vee brakes ARE worse than maguras particularly those with modulator things (wtf are they about? lol)An avid something or other would work well. Im not much of an expert on vee brakes I must admit, but I know someone who had one set up so awesome, it had a similar bite to a disc Obviously I was very startled when I pulled the brake lolBasically So long as you get a good vee brake, and set it up well, it can give similar results to a magura (in my opinion) however I wouldn't trust it as much as the cable would stretch Quote Link to comment Share on other sites More sharing options...
Janson Posted February 6, 2006 Report Share Posted February 6, 2006 everyone generalises a maggie down to a hs33. us trials riders are picky, we tend to go for the best stuff. xtr/sd7/ultimate, not alivio crap, or hs11 unless we're forced. Quote Link to comment Share on other sites More sharing options...
ian Posted February 7, 2006 Author Report Share Posted February 7, 2006 yeah like i said above i would only use the best bits anyway,i would use a cable that it already pre-stretched but if it did stretch then you can always use the adjuster on the lever,i think it is going to be one of those things that i have just got to try and find out,anybody got any pics of v-brakes on a mod which has the 4 bolt adaptors? Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted February 7, 2006 Report Share Posted February 7, 2006 i would use a cable that it already pre-stretched but if it did stretch then you can always use the adjuster on the lever,my god, at last somebody has realised that its blatantly obvious yet everyone seems to use it as an excuse linear slick cable dont appear to stretch(well mine havent been adjusted in months)as for 4 bolt adaptions, i have some pics somewhere, add me to msn Quote Link to comment Share on other sites More sharing options...
Matt_Tupman Posted February 7, 2006 Report Share Posted February 7, 2006 A v-brake can be better than a well setup magura but it'll cost you a lot moreYour talking Avid Ultimates, Xtr Levers, Heatsink pads, linear slicks or Nokons, that all adds up to a pretty expensive brake but if set up well it will be better than most peoples maguras and it's a fit and forget option Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted February 7, 2006 Report Share Posted February 7, 2006 A v-brake can be better than a well setup magura but it'll cost you a lot moreYour talking Avid Ultimates, Xtr Levers, Heatsink pads, linear slicks or Nokons, that all adds up to a pretty expensive brake but if set up well it will be better than most peoples maguras and it's a fit and forget option damn straight, altho fi you go secondhand, bargains can be had, por example:sd7-bout a tennerxtr lever, bout a tenner againlinear slick cable-may as well go new, they are uber cheap-6-7quidpads-for the rear you want some decent ones, crvs, heatsinks and spanish flies can be had for as little as 5-10quidthats like 35 for damn nice setup, whereas a similair maggy would be about 25-30, so its not really that much more expensive in my eyes, also once you have spent it, you generally dont have to spend anymore, ive managed to wear out 1 set of pads in about almost 2 years of riding, and i used to run some pretty nasty grinds, altho for the past few months ive had ceramics front and rear, so my pads havent appeared to wear at all Quote Link to comment Share on other sites More sharing options...
Guest Posted February 7, 2006 Report Share Posted February 7, 2006 But v-brakes would tend to require more maintenance would they not with regard to cable's stretching?Personally, having maggies at the moment, I would never consider putting a v-brake on my bike, if it's not broke, don't fix it eh? The way I see it, there is more to go wrong with a v-brake set-up, cables getting stretched, dirty, cable housing needs to be clean etc. With a maggie its a simple case of lining them up, tightening a few bolt's and your good to go for as long as you want provided you dont split a hose, which I havn't done just yet.....Too much hassle for no great gain in performance is what come's to mind.. Quote Link to comment Share on other sites More sharing options...
Matt_Tupman Posted February 7, 2006 Report Share Posted February 7, 2006 But v-brakes would tend to require more maintenance would they not with regard to cable's stretching?Personally, having maggies at the moment, I would never consider putting a v-brake on my bike, if it's not broke, don't fix it eh? The way I see it, there is more to go wrong with a v-brake set-up, cables getting stretched, dirty, cable housing needs to be clean etc. With a maggie its a simple case of lining them up, tightening a few bolt's and your good to go for as long as you want provided you dont split a hose, which I havn't done just yet.....Too much hassle for no great gain in performance is what come's to mind..Just buy a decent cable Linear slics and Nokons both don't stretch, i think both setups have their problems and if both are setup well they should need constant maintainence Quote Link to comment Share on other sites More sharing options...
Brian Bleech Posted February 7, 2006 Report Share Posted February 7, 2006 But v-brakes would tend to require more maintenance would they not with regard to cable's stretching?Personally, having maggies at the moment, I would never consider putting a v-brake on my bike, if it's not broke, don't fix it eh? The way I see it, there is more to go wrong with a v-brake set-up, cables getting stretched, dirty, cable housing needs to be clean etc. With a maggie its a simple case of lining them up, tightening a few bolt's and your good to go for as long as you want provided you dont split a hose, which I havn't done just yet.....Too much hassle for no great gain in performance is what come's to mind..a good cable hardly stretches at all and you adjust the barrel adjuster to alter it (same as altering a tpa) and if it is a shit cable, it's still hardly a constant problem, it doesn't all of a sudden stretch by 10cm or so! you just have to tighten the cable at the caliper, which is a 30 second job!!! Quote Link to comment Share on other sites More sharing options...
Guest Posted February 7, 2006 Report Share Posted February 7, 2006 Yeh, what im saying is that if you allready have a maggie, what's the point in changing when the performance isn't going to change significantly?It's all down to personal preferance really, I know i'd rather have a magura than a V-brake, on any bike. That's just down to my experiances with both, and i've liked Magura's more. Quote Link to comment Share on other sites More sharing options...
ian Posted February 7, 2006 Author Report Share Posted February 7, 2006 i tihnk im going to give this a try, its one of those things you just have to try,maybe it will be better for comp maybe it wont be i will never no until i try.and i said above im going to use a pre-stretched cable and im trying to sorce an xtr calipers from in for sale section and i have the added bonus of working in a bike shop. Quote Link to comment Share on other sites More sharing options...
Guest Posted February 7, 2006 Report Share Posted February 7, 2006 i tihnk im going to give this a try, its one of those things you just have to try,maybe it will be better for comp maybe it wont be i will never no until i try.and i said above im going to use a pre-stretched cable and im trying to sorce an xtr calipers from in for sale section and i have the added bonus of working in a bike shop. From what i've heard, xtr calipers won't be the best, the parrallel push linkage on them is balls really, better to get an SD7 or some other Avid..... Quote Link to comment Share on other sites More sharing options...
Ali C Posted February 7, 2006 Report Share Posted February 7, 2006 I am a firm beleiver that vees are better than maggies.I have run maggies for7 years now, they generally seem to work fine, but they are far from perfect!I find I get a lot of arm pump using maggies (even with water) as the spring in the lever is too powerful and it takes a lot of effort to pull it and keep it pulled.Also braking performance is failry good, but I find they normally only work well in one direction.a vee can be set up with minimal spring tension, which is a great thing for me as it reduces arm pump.The pads dont wobble around like maggies do, so the brakes are quieter, pads last longer etc.You can use levers with leverage adjusters to get more power if your tired (like in a comp)cables are easier to get hold of than hoses and fittings.I also find vees have UBER power when the wheel is turning backwards, great for when your tyre is bearly on the edge of an object.of course vees arnt perfect though, they take a little more matanece than a maggie (lubing the cable or replacing it every now and then).I used my vee for a couple of weeks, but as I was using a 48mm echo rim the arms went really in a great position to give the most power.I put my maggie on and have ridden it for a couple of days, but I miss my vee already. I have an alex rim on now, so I am gonna try them again once my slik cables and avid lever come. Quote Link to comment Share on other sites More sharing options...
Davetrials Posted February 7, 2006 Report Share Posted February 7, 2006 I fancy ago at these vee brake thing, mite order me sum 4 bolt converters. Quote Link to comment Share on other sites More sharing options...
ian Posted February 7, 2006 Author Report Share Posted February 7, 2006 yeah im definatly going to do it on my mod with my 48 mm echo rim see what it is like, it is goign to be tuff but im hard , so its ok Quote Link to comment Share on other sites More sharing options...
aaron_trials _247 Posted February 7, 2006 Report Share Posted February 7, 2006 no your not ian your the biggest gay aliveim back hello ian DANlol Quote Link to comment Share on other sites More sharing options...
Simpson Posted February 7, 2006 Report Share Posted February 7, 2006 no your not ian your the biggest gay aliveDan riding again??? Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted February 7, 2006 Report Share Posted February 7, 2006 yeah im definatly going to do it on my mod with my 48 mm echo rim see what it is like, it is goign to be tuff but im hard , so its okyou may find the arms will be a tad far apart with a rim like that, so you will catch you trousers/shoes on the arms, thats why you need a slimmer rim ideally Quote Link to comment Share on other sites More sharing options...
DangerousDave Posted February 7, 2006 Report Share Posted February 7, 2006 so first off, if you plan on using xtr arms and sram levers for your setup then give up now. you will have one of the mushiest feeling brakes out there.generally the most popular levers are the xtr levers with avid arms or any non linkage vbrake really. I've run the sram 9.0 levers and they have good power and a great ergonomic feel but are very very spongy.i'm running ultimate arms although they have a problem with a little plastic piece inside the brake which tends to break, so i'd probably recommend gettnig just regular avid arms although then you won't have the buttery smooth feel from the sealed cartridge bearings, not to mention no play in your brake arms. right now my setup is xtr lever, xtr cable/housing, ultimate brake arms with super cheap stock mtb cartridge vbrake pads with a grind and my brakes are still perfect even with the shit pads.I run the bonz adapters which from what i can see are about 100 times better quality and design than the heatsink adapters. plus you can adjust bonz to fit any rim size. I'm running the new echo rim on my control and i have to use the widest setting, which is perfect but i can't run a booster, although my team and control both have the booster plates welded on and i'd never even think of putting a booster on either of them. People might say the heatsinks can be adjusted up and down but its pointless because you will never ever need to adjust them downwards only up higher which they can't go. And again, bonz are just a much higher quality. So thats the adapters part...The only problem with running a vbrake on a mod is the tire clearance. I'm sure this will be diffierent on each frame, but on my 2005 team i hvae only about 2mm of clearance from my tire and the cable where it crosses over. if you have any questions just ask. Quote Link to comment Share on other sites More sharing options...
