ogre Posted January 26, 2006 Report Share Posted January 26, 2006 Whats the magical differance between metal and platic backings? there can't be anything jaw droppingly magic can there, or is the extra 10er realy worth it? Quote Link to comment Share on other sites More sharing options...
Janson Posted January 26, 2006 Report Share Posted January 26, 2006 metal backings make the brake stiffer, look bloody pimp, last longer, and make a lovely rattly noise when braking... deffo worth it unless you can't be arsed changing the pad material around when it wears down.. Quote Link to comment Share on other sites More sharing options...
Dan Clark Posted January 26, 2006 Report Share Posted January 26, 2006 Metal is stiffer and lasts longer. Quote Link to comment Share on other sites More sharing options...
Burton Posted January 26, 2006 Report Share Posted January 26, 2006 AND cheaper in the long run, since they are refillable. Quote Link to comment Share on other sites More sharing options...
scott-mad Posted January 26, 2006 Report Share Posted January 26, 2006 there awsome i could actually tell the differance when i put them on. i had an rb lever blade with coust pads and the plastic backings on them snapped even though there were the 35mm version. well worth the money and as said up there cheaper in the long run Quote Link to comment Share on other sites More sharing options...
durkie Posted January 26, 2006 Report Share Posted January 26, 2006 from what i can tell, the metal backings all have some play when they sit on the piston...the heatsink ones and the plaz ones. that worries me...the plaz ones would break your piston head off, and i feel like it's a matter of time with the heatsink ones too. Quote Link to comment Share on other sites More sharing options...
