ogre Posted January 26, 2006 Report Share Posted January 26, 2006 Would it be ok to use bmx cranks on a mod, or would it be a lot of messing around, they usualluy seem cheaper, and i can't see much of a differance, other than weight (that don't bother me). Quote Link to comment Share on other sites More sharing options...
Si-man Posted January 26, 2006 Report Share Posted January 26, 2006 You will have to run a silly great big sprocket up front (smallest is 20t but you hae to buy the KHE cranks to go with that) Wouldnt bother really Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted January 26, 2006 Report Share Posted January 26, 2006 you could get hold of the old onza adaptor that allows you ro run a front freewheel/track cogor get a ddg/betd/dmr 3 piece bash thatll let you run a 20t 5 bolt ring Quote Link to comment Share on other sites More sharing options...
narrowbars Posted January 26, 2006 Report Share Posted January 26, 2006 Would it be ok to use bmx cranks on a mod, or would it be a lot of messing around, they usualluy seem cheaper, and i can't see much of a differance, other than weight (that don't bother me).Getting a small enough sprocket?Tubular crank arms can dentheavier (even with a ti axel)They would work fine but getting a small enough sprocket will be hard. A flatland company called Quamen make a 22t. I once improted on from the us but to make it fit properly I have to moddify it as It's mainly designed to fit one piece cranks.When I moddified it it developed an up/down movement wich on a bike with either a mech or tensioner is fine because the mech/tensioner takes out and inperfections in it's shape. If you put a bike with a mech on upside down pedal it backwards and watch the mech you should 9 times out of 10 notice the mech move up/down a bit. This is because the chinring isn't perfectly round.If you mod this sprocket and run it on a mod as theres no mech/tensioner you will get an extreme tight and loose spot in the chain.Paul Quote Link to comment Share on other sites More sharing options...
